1964 inline 6 nitrous
Has anyone ever seen a nitrous plate for a inline 6
I have looked and cannot find one!! Thanks Last edited by chevelle518; 02-03-2010 at 03:07 PM. |
Re: 1964 inline 6 nitrous
i had a nova with a 250 engine . i put an aluminum intake with a 390 four barrel . , installed a nitrous plate. with a 100 shot . it ran 15 50s in the quarter . fun for a six
It's Better With Nitro
Do you have a two-barrel carb? NOS and NX both make two-barrel carb plates, if you wanted to go that route, or you can plumb a direct port system into the manifold. Or, as chopper john mentioned, you can go to a 4-barrel or 4-barrel adapter to use a more common square- or spread-bore plate system. You can check with Summitracing.com for individual nitrous parts/component (their site has decent photo details) to help you get a better idea.
