Old 02-03-2010, 07:31 PM   #1
ct4613
Anybody know what shocks I should use??
Just a quick question. Anybody find an off the shelf shock for a lowered 66 c-10? Mine are shot, and i cut coils on my existing springs. I can find factory shocks, but its lowered about 2 1/2" in front and about 3 1/2 in the rear. I found some on summits website that are for lowered c-10's, but was just wondering if anybody knew if shocks from a different vehicle would work. just tryin to keep my project as cheap as possible. Thanks for any help!!
ct4613 is offline   Reply With Quote
Old 02-03-2010, 07:36 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Anybody know what shocks I should use??
look for a shock from a 50 chysler..I think its monroe 5758 ??
Hottrucks is offline   Reply With Quote
Old 02-03-2010, 07:54 PM   #3
ct4613
Will that work for front and rear??
Old 02-03-2010, 08:02 PM   #4
Hottrucks
Hottrucks's Avatar
no I don't think so there pretty short...I still have my stock rears shocks (I'm bagged) but looking at the other frame I have it looks like the stock fronts will work on back but thats just a guess..the body of them looks to be short enough and I dont need alot of travel up?? its going to be a test?? seems to easy to be true??
Old 02-04-2010, 04:00 AM   #5
MXmaniac
MXmaniac's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=326766
Here's some good info. I'm using the Monroe shocks listed in this thread, and in the front I have 3" drop springs(and 1.5" stepped LCAs, but they don't affect the shocks) with Monroe 33033 shocks. In the rear I have manual-fill air bags, quite a bit more drop than you have, and I have Monroe 32301s in the rear.
This may help too:
http://www.monroe.com/catalog/docume...engthSheet.pdf
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 02-04-2010, 04:14 AM   #6
ct4613
Awesome. Thanks for the quick replies. This will help a lot. MXmaniac what kind of bags did you use?? And is there a build thread for dropping the control arms, or is it a kit? Now that I started, i want to go lower. Kind of addicting.
Old 02-04-2010, 08:17 AM   #7
Hottrucks
Hottrucks's Avatar
Ct check my build thread on cupped LCA and bags...I agree its like crack!!!
Old 02-04-2010, 05:53 PM   #8
MXmaniac
MXmaniac's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=335167
There's the thread for the stepped control arms.
For the bags I have Airlift Dominator 2600s, and ran 1/4" line straight out the back with schraeder fittings.
Andrew
Old 02-10-2010, 04:08 AM   #9
ct4613
great idea on the lca drop. And thanks for the shock info.
