Old 02-03-2010, 08:24 PM   #1
killacheyenne
killacheyenne's Avatar
Question lining up the hood?
i was in a little fender bender the other day and my hood got cocked to the passenger side and its touching the fender on the driver side. how do i fix this?
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 02-03-2010, 10:01 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: lining up the hood?
I would say that all of the front sheetmetal is out of whack. You will have to straighten whatever is bent before lining up the hood....
LockDoc
Leon
Old 02-03-2010, 10:04 PM   #3
jrdv
jrdv's Avatar
You need to loosen the bolts that connect the hinges to the hood.
Just barely loosen the bolts on the side that is touching the fender and try to move the hood forward a little.
You may have to play around with both sides.
There is a possibility that the hinges may have been tweeked. If the back of the hood is sticking up, you need to replace the hinges.
I just replaced the hinges on one today. It took about 20 minutes.
Good Luck
john
jrdv is offline   Reply With Quote
Old 02-03-2010, 11:02 PM   #4
pat 70/71
pat 70/71's Avatar
I would first look at the whole clip to see how everything lines up. fenders to doors hood to valance. you may get away with small adjustments. take your time really look at it. good luck hope this helps ya. Pat
pat 70/71 is offline   Reply With Quote
Old 02-03-2010, 11:03 PM   #5
BOOB
BOOB's Avatar
Check the core support alignment to. I would loosen those bolts up a bit too.
1970 Short/Fleet C-10 (Project)
-Slammed and Tubbed
1955 Cameo
-Straight six, Turbo Hydro option
1955 BelAir 2 door post
-All original down to the oil bath air cleaner
1964 Corvette
-All power A/C 327 4 spd. tanker
BOOB is offline   Reply With Quote
Old 02-03-2010, 11:25 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... front fenders and everything. Some things might need to have shims added or taken out...
My truck has a tweaked front end. I bought it that way. It got smacked in the right front corner, just hard enough to knock everything out of whack. I have been fighting with shims in the fenders, and hood hinges for quite some time. I still cannot get it to line up right. I'm close... but not as close as I want it to be.
Gary
GASoline71 is offline   Reply With Quote
Old 02-04-2010, 09:16 AM   #7
junkyardjohn
junkyardjohn's Avatar
If the sheetmetal of your hood doesn't appear bent, you probably have a couple of tweaked hinges, try opening your hood all the way & pushing hard on the front corner (sideways) in the direction that you need clearance. What you are trying to do is bend the hinges back the way they were. I hope i'm explaining this so you can understand what i'm trying to say. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
