Looking for a little help about going from a 3/4 ton to a 1/2 ton
In a couple months I am going to start tearing into my project. First thing on the list is to convert it from a 8 lug 3/4 ton into a 5 lug 1/2 ton. I was planning on buying a mid 70's 1/2 ton truck and using the suspension off that. Swapping out the rear end seems easy enough, but as far as the front goes, can I swap out the entire front crossmember? Any help would be appreciated. Thanks!!
its just $$$$$
Re: Looking for a little help about going from a 3/4 ton to a 1/2 ton
no need to swap the crossmember, just swap the a-arms and spindles
![]() Join Date: Dec 2003
I went the from a 1/2 to a 3/4 on a burb. One thing I found out was you'll need a new rear u-joint. The 1/2 is smaller than the 3/4. Napa has a u-joint that adapts the two together. Shame you not closer, I've got a good 1/2 front end.
PMed you
Hail to the King, baby. |
Slots go on anything!
The mid 70's truck should have a 12 bolt rear. You may not even need to change to a conversion u-joint.
I think I would just swap from the control arms out, like Tracey said. That would go faster, and gives you an opportunity to put new bushings in at the same time.
1974 Jimmy- 5.3/4L80e/NP241 |
