Old 02-04-2010, 02:30 AM   #1
78swest
78swest's Avatar
78 chevy swb electrical issues?
when i got my truck i could only start it with a starter switch now i got a switched wire running from the block on the firewall to the distributor wich already has wires coming from the wiring harness without this the truck has no power at all .. it wont shut off unless i switch the switch off then the key? ignition switch problemsn i dont know where to start?
78swest is offline   Reply With Quote
Old 02-04-2010, 09:47 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 78 chevy swb electrical issues?
well id start by looking at the ignition switch down the bottom of the column make sure power is going there If not its prolly a bad wire or connection between the nlock and there. also check the fusible link but that will prolly test ok and you may want to get a wiring diagram so you can trace the restof the switch wires and make sure that the wires and connections are good
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-04-2010, 10:37 AM   #3
silvereagle07
silvereagle07's Avatar
I would start with a basic test light or volt/ohm meter at the ignition switch. The red wire going into the connector should have battery voltage there with key in run position. Tehn check the same connector puple/white wire for near battery voltage in the start postion. If you have it there go to the bottom of the steering column to the neutral saftey switch and test for power on the same purple/white wire. Power goes out of the ns switch on the purple wire to the starter s terminal. If you have near battery voltage at all of these connections it will start normally.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
