Old 02-04-2010, 02:41 AM   #1
Nova70
Nova70's Avatar
Floor hump question
I tried searching this because I'm sure it's been covered but this sites search owns me... Why do they have the short and tall versions of the trans hump? Is the tall hump for the 4x4's? Will the small hump still fit on the 4x4's?
Nova70 is offline   Reply With Quote
Old 02-04-2010, 03:21 AM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Floor hump question
manual trans 2wd trucks and all 4x4 trucks had the tall hump. It was needed for trans/transfer case clearance. If you had a body lift on a 4wd you could prob get away with a low hump. other prob know more about this than me though.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-04-2010, 06:29 AM   #3
johndawelder
johndawelder's Avatar
BB automatic 2 wheel drive had tall humps as well as the 4x4's.Some were bolted in some were spot welded.
johndawelder is offline   Reply With Quote
Old 02-04-2010, 08:32 AM   #4
junkyardjohn
junkyardjohn's Avatar
TALL HUMPS ARE BOLTED IN & SMALL HUMPS ARE WELDED IN. YOU CAN CUT OUT A SMALL HUMP & REPLACE IT WITH (bolt in) BIG HUMP. HOPE THIS HELPS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-04-2010, 09:40 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
big block automatics, all 4 speeds, and all 4X4 got high humps. All others were supposed to be low hump floors.
Old 02-04-2010, 04:36 PM   #6
Jacfourteen
learn something from you everyday! I didn't know that bb autos had the high hump, and I thought all manuals had the high....shows how much I know
Old 02-04-2010, 05:34 PM   #7
Longhorn Man
Yep, big block/TH400 would get the high hump. The small handfull of big block 3 speed trucks had the low hump though.
A common mistake, many think that all TH400 trucks had it, but that's not true.
Every once in a while an oddball went out. I had a 69 C/1500 (GMC 1/2 ton) with a 305 and TH400. For some reason, it had the high hump. I figured it was the 305 V6 that did it, but after looking around, it was the only one. Even saw another SWB C/1500 with the 305/TH400... and it was a low hump.
Old 04-25-2010, 05:24 PM   #8
1969C10shortbed
I have a 69 C10 straight 6 with a 3 speed. I think it came with a factory column shifter but it now has a Hurst Indy shifter on the floor. Would this be a low hump or a high hump? I plan on replacing the entire floor because I have tons of rust, and I would like to get the correct replacement. Thank you in advance for any help. Oh, forgot to mention, I plan on swapping a big block with a T56 in later on, hope that helps on determining if I need a small hump or a tall hump
1969C10shortbed is offline   Reply With Quote
