Old 02-04-2010, 12:18 PM   #1
'70GMCStep
Engine Temp for 350
Just got the new engine on the road. Running very well. I want to break this in right, but I'm maybe a bit too concerned about the temp. readings. I am hoping that 190-205 degrees is about right for a 350? I've got stock rebuilt heads on a new crate with a edelbrock 4 barrel, and a 700 R4 behind it. Also have 4 core radiator.
Any suggestions would help, it is in the 30's here temperature wise and not sure how it will do in the summer. I do know that these things can get hot, just not sure how hot.
Thanks as always,
'70GMCStep
'65 Chevy C-10
'70 GMC Stepside
'70GMCStep is offline   Reply With Quote
Old 02-04-2010, 12:23 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Engine Temp for 350
190-210 is okay for a 350. Engines tend to run a little hotter during break in. IMO you're fine. Good luck and keep us posted...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-04-2010, 12:30 PM   #3
nomrlz
nomrlz's Avatar
some newer engines are even designed to run around 210 degrees for emissions. 190 is a normal temp for a small block and 160 is the coolest temp i recommend. try not to run at a constant rpm or load during break in. ease into the throttle, then cruise a bit, then ease back in, then cruise. basically drive like a person would that pisses you off when you're following them
nomrlz is offline   Reply With Quote
Old 02-04-2010, 12:42 PM   #4
MacAttack
283 Drama Queen
MacAttack's Avatar
Yep - my Mr. Goodwrench did the same. Got a little scary in the drive thru a couple of times, but once I got about 3,000 on it (using a 180 degree thermostat - with a small bypass hole in it), it stayed between 170-195 degrees, even in the heat of July here in SoCal. Just don't go cheap on the thermostat (get one with the canister type bottom) and you'll be very happy.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 02-04-2010, 01:51 PM   #5
'70GMCStep
Thanks for the advice guys, I appreciate it and will use it. Have a good one.
'70GMCStep
'65 Chevy C-10
'70 GMC Stepside
Old 02-04-2010, 01:59 PM   #6
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hello, I have a .060 over 350 in an S10 with a 165 thermostat in it. I am running one 16" electric fan that is pulling instead of pushing on a three core radiator. My motor has never gotten over 185 degrees even during the break in. I run an additive called water wetter and I really think that is why it runs so cool.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-04-2010, 02:17 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Yeah, WaterWetter works. I used to run in my '51 pickup with a 350, stock '51 radiator when I lived in Vegas. With the fan sitting too low, no fan shroud it never went over 200. Works very well...
Joseph Chavez
Old 02-04-2010, 02:32 PM   #8
62gmc910
62gmc910's Avatar
205 is perfect for break in and if it says below 210 in the summer the fuel milage shoulsd be better. The old school 160 stuff is just that old school it makes more power if you are sucking air from under the hood but burns more fuel and leaves more crap in the oil. Rads last longer with at least 25 % antifreeze but water with wetter cools better
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
