Old 02-04-2010, 12:55 PM   #1
76gmc
76gmc's Avatar
upper control arm studs / bolts
has any one replaced the upper control arm stud . these studs press into the cross memeber and holds the upper control arm to the frame.
if so were do you get the studs?
thanks
76gmc is offline   Reply With Quote
Old 02-04-2010, 01:40 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: upper control arm studs / bolts
LMC has them i do not blieve they press in but are grade 8 bolts. You could prolly get them at any regular hardware store if you had the right size
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-04-2010, 02:48 PM   #3
76gmc
76gmc's Avatar
The ones LMC sent me are not correct, I called them and that is all they have.
No part stores have them. Year One , Paddock etc. does not have them.
I've been on the phone for 4 hours and no one has this part.
One place said they have them but they also said it fits from 62-91 but I know 91 was not the same , so I called a GM dealer and they said no they are not the same only 73 - 87 was the same part.
Yes they do press in. the stud has splines , were it goes through the crossmember
Old 02-04-2010, 03:16 PM   #4
78 Chevyrado
Try a chevy or gmc dealer. They can at least give you a description or GM part number. If they don't have it in stock, tell them to search their network.
78 Chevyrado is offline   Reply With Quote
Old 02-04-2010, 04:00 PM   #5
chevymotocross
chevymotocross's Avatar
Are you referring to the bolts where the alignment shims mate to as well? If so, I am curious as well. Will eventually be replacing all the bushings and hardware over to new stuff. I remember when I brought it in for an alignment years ago, one of those studs snapped because they were so rusty. The alignment tech was able to use a grade 8 bolt. Actually did a fine job and I appreciated his efforts for a franchise store. Still holding up to this day.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-04-2010, 07:20 PM   #6
76gmc
76gmc's Avatar
Found them at Classic Parts of America
and these are correct.
ITEM# DESCRIPTION QTY TOTAL
74-372 (1963-91) Control Arm Shaft Bolt-Upper4
GM dealers can't get them.
Old 02-04-2010, 07:57 PM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
90-92 3/4 ton at least I do not know about ton trucks should be the same. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-04-2010, 10:46 PM   #8
pig rig
pig rig's Avatar
I rebuilt my front end last summer and I replaced every thing but control arms and I got everything through NAPA
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-14-2011, 10:23 PM   #9
SS Delux
SS Delux's Avatar
Might be a dumb question but are the shafts from a c20/30 bigger?
SS Delux is offline   Reply With Quote
