Old 02-04-2010, 05:14 PM   #1
Oklahoma
irish1966
Well it's a little hard to explain, so hopefully the pictures will help
I took the original mounting bracket, and the s-10 bracket, cut the two and welded back together. .the way I did it you wont be able to use the E-brake if you still want it, I didn't, but with a little imagination you should be able to come up with something. also whats cool is that the dimmer switch plugged right into the stock s-10 column. hope this helps
Oklahoma is offline   Reply With Quote
