02-04-2010, 10:29 PM | #1 |
3 inch exhaust too much?
The machine shop told me my engine sould be running about 10:1 compression with my 2.02 double hump heads .40 over 350 with a mild port job. They also told me a 3 inch exhaust with an H pipe will be the ideal exhaust set up for me.
I'm all for the H pipe but 3'' inch exhaust just seems like alittle much for the said engine you know not enough back pressure?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
02-04-2010, 10:36 PM | #2 |
Re: 3 inch exhaust too much?
I would think so too. I would figure 2.5" would be sufficient with true duals. Dual 3" would be enough for a really "built" 350!
2007 Sierra Denali 1995 Sierra 4x4 (426,000 miles and counting) 2002 Acura TL-S (how did THAT get here????) |
02-04-2010, 11:15 PM | #3 |
The Engine Whisperer
+1 for 2.5in. You'll be happy with the torque gains of 2.5 over 3 also.
02-04-2010, 11:23 PM | #4 |
I'd use 2.5" with an x-pipe. I use a 3" mandrel bent with an x-pipe, but I have a pretty healthy 406 with a mechanical roller cam. You will be much happier with 2.5" Good luck
02-04-2010, 11:53 PM | #5 |
2.5inch
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
02-05-2010, 12:21 AM | #6 |
motor exploder
I agree on 2.5" at the most, with an H or X. I talked to one of the guys at Pypes a little while back when I was doing research for my exhaust and was told a 2.5" setup with an X will support a 500-525hp. I wouldn't go to 3" unless I was pushing 550hp or more, especially in a street driven cruiser. I have a friend with a '77 Cheyenne swb with a 450hp 454 and he switched from a set of 2.5" duals to a 3" setup and claimed he lost some torque, but that's just a seat of the pants observation from him.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-05-2010, 12:55 PM | #7 |
On a budget like Fred Sanford
Biggest.....myth.....EVER! Back pressure is a bad thing, and you never want it in your exhaust. I do agree that 2.5" is plenty for the motor in question, but you wouldn't lose any power with 3".....just be a little noisier.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
02-05-2010, 01:58 PM | #8 | |
2.5" is plenty for that combo, but 3" would be bada$$. It did on my 355. Flowmaster sells a universal exhaust kit that works well on our trucks. That is what I made mine with. I am actually selling mine and you can see pictures in the classified section.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
02-05-2010, 02:23 PM | #9 |
Moderator
2.5" for a small block, 3" for a big block.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-05-2010, 09:15 PM | #10 |
When It comes to gettings exhaust done I may go with the 3 inch exhaust if it isn't going to hurt me.
02-05-2010, 09:39 PM | #11 |
from what i read a long time ago in a hot rod/or similar mag..... use what the ENGINE NEEDS to the muffler and after the muffler WHAT EVER YOU WANT...... a engine is a big air pump, ya just gotta figure out how big is needed to get all the air OUT thats been sucked IN.....
3" would def. sound good.. |
02-05-2010, 11:32 PM | #12 |
Hmmm.. I must have too big of an exhaust for my 347ci motor..
BTW, bellow are a couple dynograph overlays showing a mild cam and bolt on 347ci 3rd gen motor (stock heads). The lower numbers are going through 3" exhaust to the cut out then necks down to the 2.5" exhaust to the mufflers. The higher numbers are with the cut outs open IE dual 3" straight open.. I have done several exhaust similar to this, some 3" all the way through, some necked down to try and quiet it down a little.. All of them showed gains in both TQ and HP under the curve with less restriction. I was proving a lot of people wrong back in 01 about back pressure. Even with stock cams, the gains were all over.. I think a well thought out set of headers make the biggest difference with exhaust scavenging.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 02-05-2010 at 11:35 PM. |
02-06-2010, 11:04 AM | #13 | |
I'm planning to do 3" from the collector through the mufflers w/some 2.5" tail-pipes for a slightly warmed over 350 (and I do mean slightly....) because eventually it will get a 408/AFR combo sitting on the stand & I want to spend my money wisely. I figure that's a good all around compromise.
02-06-2010, 12:32 PM | #14 | |
Registered Truck Offender
I was waiting for someone to bring that up. If you have a set of super cheepie 1-1/2" long tube blackjack headers dumping into a 2-1/2" collector,, ,,, dumping that into a 3" exhaust pipe and muffler just doesn't make any sense to me. THINK the system all the way through. Good pieces here and there just don't get the job done.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
03-10-2010, 06:41 PM | #15 |
My BBC has 1.625 headers w/ 3" collectors. The old exhaust system was 2.5" thru cherry bombs and out behind the tires. All of that was cut out and 3" thru flowmasters dumping in front of the rear axle made a helluva difference. Another bonus is that it isn't really that much louder.
'77 K20 LWB 454, NV4500, NP205, 4.10's rollin on 33's passin everything but a gas station. |
03-19-2010, 04:49 AM | #16 |
"THE GREEN GOBLIN"
Im running a 3" exhaust setup my mechanic recomended for the motor he build for the truck. Others would disagree but I like it.
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
