Old 02-05-2010, 02:09 AM   #1
classicchev
classicchev's Avatar
removing door glass in a power door
Is there a easy way to get the glass down from power doors that are not wired. Any ideas, quick wiring diagrams???
Thanks,
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 02-05-2010, 02:31 AM   #2
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: removing door glass in a power door
Thanks,
Darren
you could disconnect the connector from the window motor and jump the motor with a battery or jump box...that's the only way I know of to do it...
Stitch is offline   Reply With Quote
Old 02-05-2010, 06:32 AM   #3
cochino12
It followed me home?
cochino12's Avatar
Yep, I've always used a battery from an 18v drill
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-05-2010, 07:47 AM   #4
Stitch
that's an even better solution...nice a portable...didn't think about that...great idea Adam
Old 02-05-2010, 07:56 AM   #5
LONGHAIR
Thanks,
Darren
The wiring is very simple, there are just 2 at the motor itself. Getting to them is a bit of a challenge though. I have always used a "jumper" that I made by cutting the "business end" off of the harness from a donor truck. It is just the factory connector and a few feet of the wires.
Then all you need is a battery. Touch one wire to the + positive, the other to the ground and the window will move. If it moves the wrong direction, switch the wires.
It works this way because the motor is not grounded. You give it hot and ground in the direction you need for it to move.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-05-2010, 10:43 AM   #6
classicchev
May have been doing something wrong, or the motor is pooched. The doors are in MINT condition, so my quess Im doing it wrong.
Darren
