Old 02-05-2010, 12:20 PM   #1
70Custom10Nut
70Custom10Nut's Avatar
electric choke hookup?
I just put a new Edelbrock 1406 carb on the ol'girl last night but ran out of time to get the ellectric choke hooked up. Question is this. There is a purple wire (original harness) that comes up the back that I think was the positive for the original carb. Am I right? If not, what is the suggested wire for hooking the "key on" hot wire of the choke setup? thanks, Cnut
70Custom10Nut is offline   Reply With Quote
Old 02-05-2010, 12:39 PM   #2
lovnthe70
lovnthe70's Avatar
Re: electric choke hookup?
I’m not sure if it is but that would explain why I have a purple wire going to nowhere! I have seriously always wondered about that! But you can run it to any 12v ignition source; I ran mine to the hot at the alternator as some people had advised me. Was easier than running it to the fuse box where I am out of 12v ing sources.
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 02-05-2010, 01:03 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The purple wire in your engine harness is the starter wire. You can run a wire from ignition unfused inside your fuse panel to get 12 volts to the electric choke. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-05-2010, 01:37 PM   #4
mrein3
mrein3's Avatar
When I put my 1406 on I found a wire on the passenger side of the engine that already had 12 volts with the key on. I think its intended use was for that thermal-spark-emmissions-thingy that was long gone when I got my truck.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-05-2010, 02:24 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
I ran mine to the power supply going to my TH400 kickdown switch.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-05-2010, 03:04 PM   #6
69GMCLonghorn
69GMCLonghorn's Avatar
I ran a manual choke and it was the best thing I could have done! I got tired of the electric choke never being adjusted right. Maybe I'm just a goof and didn't know what I was doing, but manual just worked a lot better for me. Another good reason to run a good ol' Holley!
69GMCLonghorn is offline   Reply With Quote
Old 02-05-2010, 03:15 PM   #7
jdcole
jdcole's Avatar
I dont know if its right or not but it worked for me. I hooked mine on my Mustang to the positive side of the coil. Guess it won't work if you have HEI but that is what i plan on doing when i hook my 1406 up when the time comes.
1969 Chevy LWB 350 converting to short stepper
My build thread
jdcole is offline   Reply With Quote
Old 02-05-2010, 04:21 PM   #8
yellow70GMC
yellow70GMC's Avatar
thats what i did, it seemed like the easiest and the cleanest. just run a ground to one of the screws on the electric choke housing and you're good. and i agree with 69gmclonghorn, i had to screw with mine for almost a half hour one day to get it to kick down right and not come back on.
1970 GMC 4x4 swb fleetside
custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters
yellow70GMC is offline   Reply With Quote
