![]() Join Date: Apr 2005
I need the following measurement for the rear axle hub (see picture). The measurement should be at the wheel mounting surface. Mine measures 3.09" (71/72). I need these for 71/72 hubs and 73-87 hubs. Please post both if you have them. I need as many responses to this as I can get to determine the variances, so please don't stop replying.
Thanks in advance. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: I need a rear axle hub measurement!!
Rob, I'll get you some numbers for the 71-72 by this afternoon & can cross check against my 74 once I get home this evening. I'll post up the info asap.
I got 3.06" on mine (both). The 74's hubs are OE/stock; the hubs on the 68 housing are Moser axles if that makes a difference to you. I was going to measure the 71/72 rear end but remembered it also has Moser axles.
Hope this helps.... Let me know if you need anything else.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-05-2010 at 10:10 PM. |
#4 | |
I have a stock '72. I measured 3-1/16" diameter
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thanks! Anyone else?
Restoration Virgin!
Hey Rob....I have a 71 stock rear end....3 1/16" here too....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Are you measuring at the base or at the outer most part?
I measured at the outermost part. There's a little bump in diameter right at the base. Did you want the thicker measurement?
That's correct, sorry I wasn't clear. Thanks DFW.
Ok, so I measure a total of 3-3/32" at the base
Restoration Virgin!
Oops...outer most part here too....I'll check it again tonight
#13 |
Geoff did you every get the measurement?
#14 |
Restoration Virgin!
Crap...i didn't...excuse my ignorance, but what would be the best way to measure at the base??...Was thinking about wrapping a string around it then calculating it out using the circumference equation
#15 | |
#16 | |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 02-11-2010 at 10:08 AM. |
