02-05-2010, 03:40 PM | #1 |
78 chevy gas issues now lol
ok so it will start up and once it warms up it seems like its over loading it will only run if you push the gas hard
mildly built 350 newer edlebrock carb cam headers highrise carb spacer and electric fuel pump which i think may be too big fuel pressure regulator set on 1 psi still too much fuel is getting into the carb ....im switching back to manual today.....the only reason i went electric is cause i ran out of gas and the manual pump was not pulling from the tank i would like to get the bugs worked out so i can make this my daily any input? .....im also bypassing the selector switch today so hopefully that will help ..i went from getting no fuel to too much |
