Old 02-05-2010, 04:31 PM   #1
68 TT
Still plays with trucks
68 TT's Avatar
78 body onto truck arm 67 C-10 frame
I know plenty of people have put the older bodies onto the 73-87 truck chassis but has anybody gone the other direction and put the newer body onto the older chassis?
I tried searching a few times and kept getting a fatal error so no luck there.
I am going to swap my 67 body onto the complete 78 K20 chassis including drivetrain to make the 67 a K20 short bed that I always wanted.
I will have all the parts left over to make the 78 a C-10 with the 67 truck arm suspension. Has anybody tried this?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-05-2010, 06:42 PM   #2
Tony@AirRideTech
Junior Member
Re: 78 body onto truck arm 67 C-10 frame
why are you wanting to swap chassis ?
Tony@AirRideTech is offline   Reply With Quote
Old 02-05-2010, 06:53 PM   #3
68 TT
68 TT's Avatar
I always wanted a 67 short bed 4x4 off-road toy and own a 67 C-10 LWB basket case truck that has no drivetrain. I also own a 78 K20 with a great drivetrain and suspension.
The 78 needs every body panel replaced except the passenger side door so I have no problem cannibalizing it for parts to build the 67 4x4 I always wanted.
The 78 is just ugly but could make a good parts hauler / work truck so if I could use all the left over parts from the 67 to get it back on the road all the better.
No point in a parts hauler getting 7 mpg like the K20 gets now or having it ride like a tractor either due to suspension designed for a camper special when it will never have a camper on it.
Old 02-07-2010, 06:07 PM   #4
andrewmp6
You will have to make body mounts and a lot of odds and ends.
andrewmp6 is offline   Reply With Quote
Old 02-08-2010, 04:31 PM   #5
Tony@AirRideTech
Junior Member
it would be easier to fit the straight axle to the 67 frame than it would be to fit the 67 to the 73+ frame.
