How to "undo" cutting back of the cab
First off, I will start with I am a complete audio nut so don't ask, "why?" please. lol.
Now, if I were to cut the back of the cab and the bed with a hole about 16" tall and roughly 28" wide or so, how would I go about reversing it in the future if I ever wanted to? Should I save the pieces I cut out and be able to weld them back in or have someone else weld them in? If I can do that, what should I use to cut the hole to keep the pieces in as good of shape as possible? If you're wondering why I would cut a huge ass hole like that, I'm thinking about doing a blowthrough build for my stereo. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: How to "undo" cutting back of the cab
Better keep the piece you cut out...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Jan 2008
I would use a die griner with a cutoff wheel to make a couple of slots, then use a jigsaw to cut the hole.Keep the piece you cut out of the cab, and as far as the bed goes, do the same as the cab. For replacement, I would re-install and weld the cab section, and replace the front bed panel. It would be easier to replace the front bed panel than to weld it back in. My .02 Good luck
#4 | |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Yup, jug saw would be the best bet, that is what i have done in the past with customers trucks.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
Or, get an aftermarket front bed panel, chop that up, and then you still have your original unmolested to put back.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 02-06-2010 at 11:50 AM. Reason: what? |
