Old 02-06-2010, 06:26 PM   #1
rex01atv
How much 2 cut off of springs???
I have a 2000 silverado lowered 5/7 and the passenger side is higher than drivers side by 1/4''. I have beltech springs, how much do I trim off to get 1/4 lowerer on that side???
rex01atv is offline   Reply With Quote
Old 02-06-2010, 07:44 PM   #2
SCOTI
SCOTI's Avatar
Re: How much 2 cut off of springs???
There is no hard rule for this. Most people are cutting for @ least 1-2" of drop so they'll cut .25 - 1 coil depending on age & condition of the spring.
Did you pull the springs out & try reinstalling them?
If you did the above, how about switching them from side to side?
If you tried both of those ideas & still have the issue, I would have a .250" spacer machined for the offending side that way you know it will be adjusted by exactly .250". They make poly-urethane spring isolators in 1" thickness (& possibly shorter). Get one of these & have a machine shop mill it down to what you want.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2010, 07:52 PM   #3
LONGHAIR
You don't need 1/4" spacer to gain a 1/4" of lift. There is a lever/fulcrum factor involved, you probably only need half of that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-06-2010, 09:21 PM   #4
cochino12
It followed me home?
cochino12's Avatar
Have you tried swapping sides? Worked on my '85
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-07-2010, 01:52 AM   #5
rex01atv
No, I havent tried any of the suggested ideas. I have installed brand new 1'' lowering springs. I've had this problem before the lowering springs, that is why I replaced my stock springs thinking they were worn out???
Old 02-07-2010, 09:39 AM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Longhair is right about the spacer measurement. maybe try something like this and then take it and get it aligned.
http://cgi.ebay.com/ebaymotors/Globa...item4ced84af83
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-07-2010, 11:59 AM   #7
rex01atv
Is that spacer going to reaise the side or lift it??
Old 02-07-2010, 01:18 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
The spacer will add height to the side you install it on.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-08-2010, 03:24 PM   #9
DKN
Active Member
Yow will need to shorten the tall spring by 0.15" to lower the truck by 1/4". As stated there is a ratio of spring travel to wheel travel. It might be easier to simply grind the end of the spring to get the 0.15" removed.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 02-11-2010, 03:32 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
I own an '01 S10 lowered 4/5, and it suffers from this "Chevy Lean". I've tried spacers from Auto Zone (not the one pictured above which actually might be better than what I'm running). Mine just go inbetween the coils to stop the coil from compressing, which in turn increases the spring rate = even worse ride.
A fix that a lot of people have done with no issues is modify the sway bar link. They remove the height difference from the passenger side's link rod that connects the link to the control arm and bolt it back up. This only requires a new/shorter bolt to be purhcased if the rod is in good condition. A lot of people were leary about it at first, but there are people running like this for 3 years now on their daily drivers with no problems.
I plan on doing this to my S10, but waiting until I get new shocks so I can do it in one fail swoop...
Here's the link the sway bar mod: How to correct Chevy Lean
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-24-2010, 03:44 PM   #11
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
thats good mod to know cause i know alot of people that have this same problem.
staggerd86c-10 is offline   Reply With Quote
Old 02-24-2010, 04:41 PM   #12
Slow Build
Slow Build's Avatar
Does this mod make the truck lean more one way than the other when cornering since there is a pre-tension on the sway bar?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-24-2010, 05:34 PM   #13
tubbedII
needs more $$$
tubbedII's Avatar
I still haven't done it myself, but from what others have said there is nothing noticable about the change other than the ride height. I'm no engineer, and I don't know if anyone on that board is, so if anyone with more knowledge on this type of thing wants to chime in before I take the plunge, please do so!
1970 2wd Blazer
Old 02-24-2010, 10:28 PM   #14
rex01atv
I heard today from a guy if you cut off a 1/4" of coil you will get a 1/2 drop and so on. He said whatever you cut, times by two and that is your drop??? Any feedback???
Old 02-24-2010, 11:30 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Scoti already answered this. It depends on the age of the spring and the truck it's in. Your results may vary....
Articles-
"Refining Sierra"
