02-06-2010, 08:24 PM | #1 |
maybe I'm blind...Choke??
I posted a question earlier about hooking up my new electric choke. I ran the hot wire to the fuse box and plan to hook it into the "unfused IGN" hook up. Question is do I hook it in to the one with the little arrow (bottom) or the top one? I hooked it to the top one any went out for a drive, but the choke didn't seem to work(ran real sluggish until it warmed up), but then again, I haven't adjusted the choke yet either. Cnut
02-06-2010, 08:30 PM | #2 |
Re: maybe I'm blind...Choke??
ANY 12 VOLT SOURCE WILL WORK. I USUALLY TAP INTO MY HOT LEAD GOING TO MY HEI. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-06-2010, 08:43 PM | #3 |
Could I get away with hooking it to the + side of the coil? Someone mentioned that but the Edelbrock instructions say not to.
02-06-2010, 08:56 PM | #4 |
I'M SORRY... I JUST ASSUMED YOU WERE RUNNING A HEI DIST. YOU NEED A FULL 12 VOLTS & THE HOT WIRE TO A POINTS STYLE DIST. IS ONLY ABOUT 9. (PROBABLY WHY EDELBROCK SAYS DON'T DO IT) A JUNKYARD HEI IS ONLY ABOUT 30 OR 40 BUCKS, & IS A MAJOR WORTHWHILE INVESTMENT. I WOULD VERY HIGHLY RECOMEND FOR ANY CARBED CHEVY MOTOR. JOHN
02-06-2010, 09:05 PM | #5 |
good guidance, But I converted my points to electronic with a Mallory kit (under the stock cap) a few years back. I would think that I now have 12 volts, do you think?
02-06-2010, 09:18 PM | #6 |
I don't have any experiance with mallory dist. But i'll bet it does. If you have an electrical tester with a "volts" mode it easy enough to check. John
02-06-2010, 09:20 PM | #7 |
Don't mean to hi-jack , but what kind of Eldebrock are you running ? Everything but the choke rod hook up ok ? THANKS !
02-06-2010, 09:24 PM | #8 |
Redefining LowBudget
just follow the wire from the dizzy ...it HAS TO go back to your fuse panel....if not check the FAQ for install on an HEI and correct both problems......
If your going to step up to HEI Skip White...brand new $50.....dont waste $$ on junk yard ones
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-06-2010, 10:54 PM | #9 |
It's the 1406 (600 cfm w/elec choke)
02-06-2010, 11:08 PM | #10 |
Did you hook up the ground on the choke? It needs to hook to a carb mount stud... check for 12volts at the Choke...
If it's cold out you should be able to trun the key on (don't start) and watch the electric shoke butterfly move with the air cleaner off...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-06-2010, 11:12 PM | #11 |
Just thinken here, but if you did a test drive and the choke wasn't workin sounds like you have it backed all the way off to start with? The electric part heats the pot in order for the choke to open up. Don't know about anyone else, or your carb setup but the way I setup my choke is to set it, engine cold, and turn the cover until the choke closes completly and lock it down, thats the start point, if you need more or less just tweek it from there. have you checked to see if you are getting 12 volts at the choke? I ran mine to the fuse panel and just hooked into an ign power lug, I did put an inline fuse in at the fuse box though for safety. Good luck!
02-06-2010, 11:35 PM | #12 |
come on guys... Cut it out... It's one 12 volt hot when the ignition is on wire hooked up to the red choke wire. I just cut the black ground wire about two & a half" long, crimp a ring connecter on it & put it under one of the three screws holding on the choke adjust. Cap. Thats my ground. If it's a new carb 99.9999 times out of 100 the choke will be just fine just where the factory set it. Were not talking rocket science here... It's 1 wire. If you have to adjust it.. Read the owners manual... They explain it pretty good. Sorry for the confusion & hope you can clearly understand the message i was trying to say to your original question. john
02-06-2010, 11:50 PM | #13 |
When i said hook it to the coil+ i failed to mention i was running a full MSD 6a box and distributor also.....sorry about that.
