Old 01-30-2003, 12:15 PM   #1
Speedster 229
What is the cad plated hoop for ???
My 70 1/2 ton 2wd has a cad plated horseshoe bracket bolted to the top of the drivers side frame rail between the fire wall and the upper A arm.It is about 4" long and rises about 2 " above the frame rail. What is this bracket for??? I couldn't tell when I disassembled the truck and now am wondering if I need it as I reassemble? Any help will be appreciated.
Speedster 229 is offline   Reply With Quote
Old 01-30-2003, 12:47 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
That is a fix for motor mounts that could break and cuase the accelerator to stick wide-open. Not sure if it was a recall or voluntary. There would have been a cable attached to another bracket on driver side of engine. The purpose was to prevent torque from shifting the engine out of place. Remember in 67-70 these trucks had a stiff rod linkage to carb, not a cable one as used in 71-up.
I've seen NOS ones on ebay before
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-30-2003, 12:49 PM   #3
Speedster 229
Thanks, so It is a torque strap like they used to use on a muscle car. I think I'll take my chances and eliminate it. Thanks again.
