Old 02-07-2010, 01:10 AM   #1
skoffice
skoffice's Avatar
How about 20's?
Hey guys I'm going to be running the CPP modular 2-1/2" drop spindles with 3" springs, maybe cut half a coil out as well. Will I be able to fit 20's with a 35 series tire under the inner fender without any rubbing issues?
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-07-2010, 02:31 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: How about 20's?
I believe it will work. My 18's are about 26.5'' tall and I have a bit over an inch clearance. I think a 245/35/20 is about the same diameter. I would NOT cut the coil until you check your clearance
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-07-2010, 04:31 AM   #3
skoffice
skoffice's Avatar
Re: How about 20's?
That's what I was thinking, wait and see before I cut the coil. What kind of offset should I run up front for the best clearance? Wow only an inch huh? That's cuttin it pretty close!
Old 02-07-2010, 12:34 PM   #4
protrash64
protrash64's Avatar
Re: How about 20's?
I would run at least 5'' .......mine are 5.25''bs and my 20's were 5.5''bs. I had no rubbing issues.
Old 02-07-2010, 02:31 PM   #5
skoffice
skoffice's Avatar
Re: How about 20's?
Sounds good to me. I'll probably go at least 5.25 depending on whats available then. What drop do you have?
Old 02-07-2010, 03:34 PM   #6
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: How about 20's?
im running 20x8's with a 255/35/20 with zero rubbing issues, its ot 3 inch spindles and bags.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 02-07-2010, 05:02 PM   #7
protrash64
protrash64's Avatar
Re: How about 20's?
Exactly yours.......2.5'' spindle and 3'' coils.
Old 02-07-2010, 10:52 PM   #8
skoffice
skoffice's Avatar
Re: How about 20's?
That sounds awesome. Thanks for the input guys! I was worried about ordering my wheels and tires and then come to find out "ah crap I'm rubbin!" Thats what I'm going to be running is probably 20x8 and 255 35. Out back I think I'm going 20x10 and 315 40 or something like that. Considering the Boss 338s or 336s in black.
Old 02-08-2010, 11:43 AM   #9
protrash64
protrash64's Avatar
Re: How about 20's?
Just wanted to add something I just thought about, too. I'm running conventional dropped spindles which widen the track width, about 3/4'' on each side. I'm not familiar with the specs on the modular spindles but you may want to check to see track width specs. If they do not widen track, then you may be able to run a little less backspacing.
I've heard there are fitment issues with the Boss wheels as they are for cars and do not fit the truck hubs as well. The issues can be overcome, but you may be doing some machine work or spacers to get 'em on. FYI.
Old 02-08-2010, 01:14 PM   #10
skoffice
skoffice's Avatar
Re: How about 20's?
I was told when I bought these spindles they are supposed to bring track width inward 1/2" inch. Some redesigned spindle that you get to spend more money on hmm I did not realize that with the boss wheels. If it's just a matter of machining the hub diameter that's no problem, but then again I haven't really done any research on these wheels yet. I'm sure someone on here has to have a set of 338's? Pretty simple, popular, torque thrust design..
Old 02-08-2010, 04:46 PM   #11
Slow Build
Slow Build's Avatar
Re: How about 20's?
Here's a thread on that.
http://67-72chevytrucks.com/vboard/s...d.php?t=352320
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
