Old 02-07-2010, 02:14 AM   #1
nightmare
nightmare's Avatar
Question about rear gear choice
I know, I know, another thread about which gear to use with a 700R4. I know most have said to go with a 3.73, but that's with a 28" tire. I've got a 30" tire, and am wondering if a 3.42 wouldn't be a better choice. Right now, I've got 3.08's, and do not like how the gas mileage dropped like a rock.
Does having a longbed adversely affect mileage? I'm just wondering how people are getting 18 to 20 mpg in these trucks.
I'm not expecting that type of mileage, just something more than the 12 I used to get with my TH400.
I've got a longbed with a stock 350, will have a fairly fresh 700R4, and am wanting to choose the right gearing for this combo. I would also like input as to which ring and pinion company (Richmond, Precision, etc.) would be better to use, or which to stay away from. Any thoughts?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 02-07-2010, 04:21 AM   #2
highperf4x4
Re: Question about rear gear choice
If you're running a taller tire then you should go with a lower gear, not a higher one. I would still recommend the 3.73
If you want 18-20 mpg then you'd want to install an lsx motor. Adding overdrive to a gen1 carbureted engine isn't giong to get you there.
highperf4x4 is offline   Reply With Quote
Old 02-07-2010, 06:24 AM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
+1 on this.
I've used Richmond in the past with good results. That's all I know...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 02-07-2010, 08:04 AM   #4
big_al_71
big_al_71's Avatar
I also agree about using a modern fuel injected motor to get near the mpg range you are looking for. I went with 373's and an Auburn posi unit...and I am lucky if I get 8 mpg
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-09-2010, 11:29 AM   #5
nightmare
nightmare's Avatar
Thanks guys. Any other opinions?
Mike
67-72 FAQ
Old 02-09-2010, 11:44 AM   #6
kwmech
This..^^^
The 700 has an overdrive ratio of 28%...... going on that premise,
the 3.73 with the 700 is going to give you a final drive of 2.68.
3.73 x .72
Old 02-09-2010, 12:00 PM   #7
cdowns
cdowns's Avatar
MPG// synthetic oils and grease in engine tranny rear and wheel bearings/front end alingment no slop from worn parts//tires pressures and size//right foot and driving style/ overdrive lockup tranny//lowering for less airflow under truck//efficient intake and exhaust flow//properly timed and tuned engine
those are a few of the most common mileage "secrets"
