![]() Join Date: Jan 2007
Top to body weatherstrip
What did you guys use for weather strip between the bedsides and the top?
Re: Top to body weatherstrip
Bought mine at LMC trucks
SKINNY TIRES RULE!
just about any broad vendor should be able to get them for you.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Quality ok or any I should avoid?
I was curious of the same thing myself.....
SKINNY TIRES RULE!
I've said it before, but I seriously doubt there are many different manufactures of Blazer specific weatherstripping if there is even more than one. There were less than 80,000 Blazers manufactured between 69 & 72. If you factor in how many have met their demise, tops removed, or already running new weatherstripping and there isn't much market left. If there is more than two manufactures, I'd be surprised.
That said, I purchased a full set of top weatherstripping from LMC. It all fit ok, but the door seals that contained metal from the factory did not have the metal. I had no problems with the bed-to-top strips.
I bought all my weatherstripping from LMC.....no complaints.
In fact.......very good to do business with in my opinion.
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. Last edited by scoyote; 02-08-2010 at 12:35 AM. |
K5drive
Just currious about the material most are having success with to bond the door weather strips on with .I tried two or three differrnt recomended adhesives but not having much luck .
I used the 3M Super Adhesive, the black stuff.
But first I wiped the inside with alcohol to remove dirt/oil.....because when I didn't do that it wouldn't stick at all.
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
SKINNY TIRES RULE!
![]() I tried contact cement, but it didn't hold long. While the top was hanging in the garage last summer, the header seal fell off. I used the 3M adhesive remover to get all the old stuff off first.
I've used 3m black and yellow weatherstrip adhesive, and the yellow is best in my opinion.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Well I'm a tightwad so I just went to Lowes & got some weatherstripping. Kind of like this pic in that it had little ribs like this, but it was about twice that thick & black. Worked good! Has sticky on one side already, but I added a little yellow 3M, or "gorilla snot" as my daddy called it, for a little extra.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#13 |
K5drive
Thanks fore that info didnt mean to hijack thread but though its closly related and good info Thanks Again
