Old 02-07-2010, 10:10 AM   #1
Mil-Spec
Mil-Spec's Avatar
Newb 4x4 Questions
Hey guys.
I picked up my 1st 4x4 truck back in Nov. It's a '79 K20 Suburban. The recent snow we recieved here in Ohio (13 inches in some places) has been the 1st real time I got a chance to used the 4x4 function. It felt great and had a real good connection to the unplowed surfaces.
A couple of questions I had after driving around with the 4x4 engaged:
1. When I turn the wheels tight in either direction, while moving forward I feel the frontend jerking or what feels like binding. Is this normal for these straight axle trucks?
2. When not using the 4x4 function and with the hubs not locked. Is it hurting anything by leaving the transfer case in Hi-loc? I know the know the knob on the shifter handle says Lo-Loc, Lo, N, Hi, Hi-loc, but it doesn't feel like I have that many detents or selections. Should it definately be in "N" when not using 4x4?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 02-07-2010, 11:10 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Newb 4x4 Questions
Yes, it is normal for a more aggressive grabbing when your steering clocked to the right or left.
Second, all drive power goes through the transfer case. In your case it is a NP203. So if you were to put your t case in N it would be the same as putting your transmission is N. As for Hi vs. Hi-loc, I am not familiar enough with the 203 to know what the recommended gear setting. My guess would be Hi.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 02-07-2010, 11:24 AM   #3
msgross
msgross's Avatar
Hubs locked? do they have locks on them? unless someone did a conversion then it should have smooth caps over the front hubs.
My 79 blazer had a 203 transfer case (sounds like yours does). Do some reading on the NP203, it's a full-time 4WD case that is always able to turn the front or rear wheels. When you put it in Hi-loc then it's a real 4 wheel drive truck.
The sharp turns in 4WD should be avoided on dry ground,
here is some info
http://www.4wheeloffroad.com/howto/47538/index.html
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-07-2010, 12:58 PM   #4
Mil-Spec
Mil-Spec's Avatar
Thanks Rid'in High and msgross.
I'm just starting to become familiar with these trucks, so that's why I'm deferring your guy's knowledge.
It has WARN hubs on it now. I supposed it could have been converted. The Suburban was refurbished and used by a local Fire Dept in 1990 and then sold off in 2003. It even still has the Lights & Siren.
From the factory it would of had smooth caps on the front? The only 4x4 versions of these trucks that I've had exposure to have been the CUCVs which also had locking hubs.
Thanks for the link, I'm gonna start reading after I send this reply
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-07-2010, 01:58 PM   #5
msgross
msgross's Avatar
my 79 Blazer had smooth covers on the hubs... it could have been converted then.
With the hubs unlocked and the TC in Hi will the truck move? If not then it only had a hub change and not a TC upgrade. If it has to be in Hi-loc to move then that would also support that idea.
The Garage:
Old 02-07-2010, 02:05 PM   #6
Benelli
Watchin the rust grow
Benelli's Avatar
Theres the chance that the PO could have just put in the hubs and not converted the t-case. I've seen it a few times.
To find out, unlock your hubs, slap your t-case in Hi and see if it'll spin the rear tires when you floor it with the brakes on. I would do this on gravel so it's easier on your tires.
If it spins the rear tires then it has a part time kit and you NEED to drive it in four wheel drive once every fill up or you'll burn up your transfer case.
If it just makes noise and doesn't move then it should still be full time 4wd and you might as well leave the hubs locked because they're not doing anything.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-07-2010, 02:49 PM   #7
cowboymike51
my brother has a 79 chevy pick up and it has a granny 4 speed in it, with a 205 trasnfer case and warn lock out hubs up front and it is all stock.
cowboymike51 is offline   Reply With Quote
Old 02-11-2010, 01:13 PM   #8
Mil-Spec
Mil-Spec's Avatar
It has been converted.
I flipped down the sunvisor yesterday and found a 4 placards. Two appear to be factory applied, 1 about the emmisions with an image of a catalitic converter on it and the other stating that the truck is a full-time 4x4 and goes on to give instructions on how to use the T-case selections.
Next two appear to be applied later. The 1st one is about the WARN lock-outs and their usage. The 2nd is a placard stating that this vehicle has been converted to part-time 4 wheel drive by DOUG NASH EQUIPMENT of Franklin, TN.
Does anyone here know more about DOUG NASH EQUIPMENT and what all is involved in their conversion process?
I plan to call the F.D. that used the truck and ask them if they had the conversion done or if it was a PO or the dealer. I'll post pics of the placards after work.
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-11-2010, 02:33 PM   #9
ghettoluxury
ghettoluxury's Avatar
Originally Posted by Benelli View Post
If it has a part time kit and you NEED to drive it in four wheel drive once every fill up or you'll burn up your transfer case.
I have been running 203's with part time kits for years and have never heard such a thing.
Doug Nash made the part time shaft as well as Mile Marker (who is the only one still producing this part). If you look at the back side of your transfer case ther is a round cover on the lower portion this is removed to access the shaft that is changed out.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-11-2010, 02:51 PM   #10
Mil-Spec
Mil-Spec's Avatar
Actually interestingly enough the DOUG NASH placard does state that the 4WD should be used atleast once a week.
Wish i had realized this before, but it seems to work fine so far.
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-11-2010, 03:44 PM   #11
msgross
msgross's Avatar
I also "heard" that Mile marker bought the Doug Nash design and is the only one selling the conversion.
The Garage:
Old 02-14-2010, 11:08 AM   #12
Mil-Spec
Mil-Spec's Avatar
Just getting around to uploading these pics for anyone who might be interested.
Placard for a long since gone catalic converter.
Full-Time 4x4
WARN Lock-outs
Doug Nash Equipment & Enineering (DNE2)
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-28-2010, 08:26 PM   #13
70jimmy
70jimmy's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
1972 CST Blazer 350/350/205 tilt, ac, white with blue highlander plaid interior
1972 CST Jimmy 350/4speed/205 med red with black interior
1972 K20 Custom Deluxe 350/4speed/205 white/ochre/white/ochre
1972 CST Blazer 350/350/205 tach, ac, warn 5687 winch, light yellow with saddle interior
1972 CST Jimmy 350/4speed/205 dark olive with olive interior
70jimmy is offline   Reply With Quote
Old 03-04-2010, 03:21 AM   #14
84 400
Sb 400 club
84 400's Avatar
Okay here you go. Mile marker bought the doug nash rights in the late 90's. Mile marker is currently one of if not the only company still making this kit. Being a doug nash you have the best kit available at the time... The full shaft replacement kit!!!
You should be in 4 hi while driving on the street.
here is your old shift pattern for the transfer case
lo loc
lo
n
hi
hi loc
and now
4 wheel low
2 wheel low
N
2 wheel high (street driving)
4 wheel high
here is the original install instructions provided by a fellow board member
http://67-72chevytrucks.com/vboard/s...ight=doug+nash
here is a vid i made about how to install and remove the kit. IT might help give you a better understanding
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-04-2010, 08:37 PM   #15
OrrieG
OrrieG's Avatar
I converted my 203 with a Doug Nash shaft in 1985. I had the rest of the transfercase freshened up at the same time (new chain and chain gears, every thing else was ok). I drove it as my daily driver until 1998 averaging about 6-8k miles per year. I did not do anything special between the regular snow we used to get, fall hunting and summer camping trips 4wd got used at least once a month. This build I pulled the chain cover and found everything looks ok, buttoned it back up an expect to use it the same way when I get back on the road. If yours does not get driven off road often then you probably should exercise the hubs and tranfercase once a month or so, but not on asphalt. I suspect the once a week or every fill up warnings are just ways for manufacturers to void warranties.
OrrieG is offline   Reply With Quote
Old 03-04-2010, 08:57 PM   #16
winchster
winchster's Avatar
Actually, it is for the health of your transfercase. My research and in my travels to discover all I can about my new ride has led me to the following opinion, that seems to be widely held around the 4x4 community:
If you didn't have any problems then you were lucky. The oil pickup only functions as a result of shaft rotation. It is recommended on a daily driver to lock the hubs and drive to work once a week.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 03-05-2010, 03:16 AM   #17
84 400
Sb 400 club
84 400's Avatar
you do not need to lock the hubs to drive the front shaft. simply shifting into 4x4 with the hubs unlocked will turn the front output spinning the oil pump. Thus it can be done on dry pavement since power is not reaching the tires. So if you want to fallow the sticker to a "T", shift it into loc position after fill up. you will hear some noise since the front shaft is spinning but if your hubs are working right it will not hurt the axle joints, stretch your chain or other related parts.
Also for those who installed the hubs and not the part time kit this is not the way to go. It will cause premature wear on bearings. With out force back on the front output over a prolonged period of time slop will develop.
1985 C10 LWB Sold
