Old 02-07-2010, 11:58 AM   #1
71 c10 rat
Question Air Bag Questions?
i have been looking around at build threads and i want to run air bags on my truck. i was hoping to get some advice, i have never messed around with air bags before. i have two goals in mind right now, running 20's and setting the frame on the ground. hopefully you can recommend some good companies to get parts through and maybe a list of what i will need to accomplish a bagged 71 LWB. thanks for all the help i will start a build thread when i start taking the truck a part
71 c10 long bed 454/TH400
"chrome wont get you home"
71 c10 rat is offline   Reply With Quote
Old 02-07-2010, 12:48 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Air Bag Questions?
I have a 70 FLWB and heres what I have learned in the last year about it.
first off if you want to lay frame your talking a hole diff animal..your going to loose your stock heater box have to do something about your hood hindges, your going to need drop spndles and and X member and your bed floor has to be raised or cut then theres the rear suspention???...... dont for get about an exhaust....
about bags..do it they ride great take a load and are a pretty easy install
Did I mention budget??..
check out my build and some others and get an idea if you can do it and if it fits your budget
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-07-2010, 03:43 PM   #3
71 c10 rat
checked out your build! bada$$ truck. i'm going to keep looking around and figure out a budget for my build. thanks
Old 02-07-2010, 03:55 PM   #4
Hottrucks
Hottrucks's Avatar
NP once you get a working budget figure out a time frame too...I try to keep my truck from being down for to long..that being said I'm getting ready to tear mine down for a month or so..I have alot of work and parts..if it was spring each would take a weekend or so but since its cold out and the roads are salt cover I'm going to pudder
Jeff
Old 02-07-2010, 07:05 PM   #5
miracle whip
miracle whip's Avatar
Hey i recomend air lift in lansing michigan, They have a kit for this truck pretty cheap. I like air ride tecnoliges but i think its way to expensive, i mean $7000 for a kit?? They must be crazy. I am putting bags on my 67 right now i just did the monster notch lastnight, Its alot of work but i think its worth it. if you know how to weld and fabracate you can do it under id say $2000 with steel and everything.
As long as your bags are mounted pretty straight and not rubbing anything you will love it!
miracle whip is offline   Reply With Quote
Old 02-07-2010, 07:58 PM   #6
jlaird
jlaird's Avatar
2 options: Porterbuilt OR dust off your welder!
jlaird is offline   Reply With Quote
Old 02-07-2010, 07:59 PM   #7
71 c10 rat
i can weld and do fab work, i just have never done anything with air bags before. miracle whip do you have a build thread going? if not i would like to see some pictures of your set up if you dont mind. thanks
Old 02-07-2010, 08:12 PM   #8
71 c10 rat
jlaird im checking out your build right now, it really doesnt seem as hard as i thought it would be. who did you buy your bags through and did you buy it all together or piece by piece?? thanks for the help guys
Old 02-07-2010, 08:28 PM   #9
miracle whip
I just became a member today, i dont really know where to find the build thread but id like to put some pics up. If you tell me how to do that i will put some pics up!
Old 02-07-2010, 08:41 PM   #10
71 c10 rat
miracle whip to post some pictures just click on reply to thread, to right of the FONTS box their is an attachments box to post up pictures. as far as build threads you would have to start one of your own under the projects thread.
Old 02-07-2010, 09:01 PM   #11
miracle whip
22065_1198831539817_1499375134_449799_1468228_n
Old 02-07-2010, 09:03 PM   #12
miracle whip
Ok that didnt work im going to try to figur this sight out, ill put some pics up as soon as i figure out how. Sorry!
Old 02-07-2010, 09:08 PM   #13
miracle whip
Here is the notch im thinking about mounting the bags on top of my axel
Old 02-07-2010, 09:10 PM   #14
miracle whip
Thats as far as i got but it will have a 4 link and it will be a little lower when im done.
Old 02-07-2010, 09:16 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board miracle whip!
There is a "Projects Section" as a sub-forum to the main 67-72 Message Board.
You can start your own build thread there.
You know we will need more pics as your project progresses.
Old 02-07-2010, 09:46 PM   #16
71 c10 rat
thanks for the pictures and the feed back guys
