Old 05-23-2002, 09:35 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Question Alternator problem
My alternator has developed a hiccup, when the engine is running my amp guage bounces, the lights flicker, radio flickers,and the dash lights flicker, I checked the alternator it is putting out 15.6 volts (high output alt. by the way) single wire, self energizing, ground straps are hooked up two to the motor and one from inner passenger fender to frame. There are no bare wires touching or anything like that. Please help!!!!!!!! Also the battery is new with full electrolite.
[This message has been edited by BLACK AND BLUE 67-72 (edited May 23, 2002).]
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 05-23-2002, 09:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Even though you have it grounded, that's what it sounds like to me. Try testing your ground with an multi meter.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-23-2002, 10:00 PM   #3
Zkast
Zkast's Avatar
Post
Depending on the style of battery you have, make sure the electrolite is full. Have it tested to verify its ok.
Even with a high output (AMP) alternator, 15.6 is high. 14.8 or there abouts is what you should be seeing. If the volts are up that high with a pulsing effect I would say its the battery. Yes a bad battery will induce a overcharging problem
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Webmaster/Team owner
www.zkast.com
Garrett - Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-24-2002, 06:46 AM   #4
JimKshortstep4x4
Smile
If your ground and battery are good, it has to be the internal regulator. From the symtoms you are describing, my first thought
would be the regulator is bad.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-25-2002, 03:25 PM   #5
Firefighter
Post
Any other opinions?
72Chevy 350 Auto 67 GMC 350 4 speed Yellville, Ar. USA
Yellville, Ar. USA
Old 05-25-2002, 05:53 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
Post
I agree with JimK 100%. My friends Dodge used to do that all the time, and it was the regulator. Same with my friends 68 chevelle. I'm saying the regulator is probably bad.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
