![]() Join Date: Sep 2002
Bed Offset Washers
I'm ready to start drilling my bed wood but I'm not sure exactly how the offset washers are supposed to be positioned. I did a few searches and it looks like they are to be rotated until the the bolt aligns with the holes in the sills and frame brackets. Am I correct?
I guess they don't necessarily have to be all in the same position. In other words, the hole where the bolt goes through can wind up at any clock position, correct? |
IIRC, when I did mine, all the washers are supposed to go one direction. It's been a couple of years, and I ain't getting no younger. To cold to run out to the garage right now to look.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Re: Bed Offset Washers
I would get the bed on perfectly square and lined up...then see what position they need to be in to mount to the sill...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Yeah, I just did another search and found the stepside instructions for the bed installation on mar-k. They also say to orient the washers with the hole towards the front. They also say to drill a 15/16" hole! That leaves a lot of room for any possible mis-alignment but, dang, that's a big hole!
I still don't see what the purpose of the offset is for. |
Still livin the "dream" in '54
I'm sure there has to be a good GM reason for the offset, but when I did mine, I just used good 'ole washers and I haven't had any issues. I just couldn't come up with any good reason (for me) as to why you NEED them to be offset. And I didn't drill a hole for the washer...
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 02-07-2010 at 02:09 PM. |
#6 | |
I guess I'm too much of a "symmetrical" kinda guy to have them all rotated in different positions. I'm sure I can get the holes drilled close enough to rotate them all in the same position. |
This is from Mar-k's site, it can be found in this instruction manual http://mar-k.com/67-72conv.pdf
19. Drill a 1/8" pilot hole completely through the boards in the center of each of the marked locations. 20. Turn the boards over and measure forward from each pilot hole exactly 3/16" towards the front of the board and make a mark. See figure 22. 21. Using a 1-9/16" Forstner bit, a drill press if available, or a hand drill, countersink each bed-to-frame location approximately 1/8" to 3/16" deep on each mark from step 20. This offset hole is for the offset washer supplied in the bed bolt kit. The offset washer keeps the bolt from turning in the wood board. See figure 23. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#8 | |
I'll be installing the washers all in one direction like the Mar-k instructions. Thanks Jeff! |
I'm not far off from undertaking the same operation. I'm under the impression the entire effort can be skipped and the bolts can simply be hidden under the bedwood by drilling a divot in the undersides to accomodate the bolt heads. I have to assume others smarter than me have come to the conclusion the strip bolts will hold the bedwood down just fine.
Please understand I have not fully thought this through and I'm only repeating something I heard quite some time ago.
71 GMC 1500 LWB |
I believe they drilled the hole off center so it would not turn when tightening from underneath.But I could be wrong.
