Old 02-07-2010, 02:59 PM   #1
dnandez
dnandez's Avatar
72 Blazer 6 inch lift
banghead:I live in portland and drive a newly lifted 72 K5. I have a 6 inch with 35s and the thing wonders all over the road now. I put in all new body mounts, new ball joints lower and upper, a raised steering arm, dual steering stabilizer. it drove straight before and now it wonders. Any ideas? I heard if I take the degree shim out of the front spring pack it should help. Is that true? How is yours set up?:
72' K5 Blazer
71' K5 2wd conversion project 454 ls7
71' C10 Cheyenne long box 66k original miles
dnandez is offline   Reply With Quote
Old 02-07-2010, 03:52 PM   #2
desertrat
desertrat's Avatar
Re: 72 Blazer 6 inch lift
The degree shim will give you less caster and probably make your truck wonder.You need to check your caster and see what you have.
The shim is there to change the degree on your u-joint so your front drive line doesn't bind so much, which is another thing you need to check.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 02-07-2010, 04:26 PM   #3
LONGHAIR
Yes, and I really wonder why these companies still do that? but they have for more than 25 years. I guess they think most people would rather have the driveshaft fit w/o any more effort than have it drive straight?
Be forewarned, you will probably need to have your drivehsaft worked on to improve it's ability to make up for that angle, but you will get your caster back and it will be much more stable on the road.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
