Old 02-07-2010, 07:19 PM   #1
TwoFiftyShifter
Will slightly taller tires alter my mpg?
So since I got a tach and GPS in my truck, I've been checking the mpg alot, and at 60mph 2200-2300 tpm on highway I'm getting 14.5 mpg. City is 10-12. I currently have 245/75/16 tires on there, and I want something just a little taller, and was thinking of 235/85/16. They seem to be an inch taller, and would look a little better. This change is too small to negatively affect my mileage, right? I have a 87 V20 350TBI, 3.42 and a 4 speed.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-07-2010, 07:55 PM   #2
Benelli
Watchin the rust grow
Benelli's Avatar
Re: Will slightly taller tires alter my mpg?
Gear ratio calculator says it should improve it by shutting off 100 or so RPM's.
I'm not sure if an inch is enough to cause worse gas mileage when your getting it roller.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-07-2010, 09:08 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
I wouldn't think a inch would make any difference with a stick but could fathom it would with a auto due to pre-set shift points.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-07-2010, 09:16 PM   #4
Benelli
Benelli's Avatar
I suppose.
Though since they are vacuum controlled, I don't see how they are pre-set.
Old 02-07-2010, 09:28 PM   #5
Restrorob
Restrorob's Avatar
A auto shifts when IT wants to, A stick shifts when YOU want to....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-07-2010, 10:14 PM   #6
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Make sure you don't increase width. That will certainly decrease mileage due to friction.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-07-2010, 10:28 PM   #7
bikes&bowties
bikes&bowties's Avatar
1 inch with the same tread and width may actually help flat highway cruising
bikes&bowties is offline   Reply With Quote
Old 02-08-2010, 11:10 AM   #8
James McClure
One shot, one kill.
A 1" difference in height will be a 3" difference in circumference. If the tire covers 3 more inches with every rotation, every 4 rotations is a foot, so every 21,000 rotations is a mile that you wouldn't cover with the smaller tires and every 13 miles is a gallon of fuel. Over the life of the tires, the fuel savings will pay for the tires. Just something to think about. I'm bored, it's winter & I have nothing to do.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-08-2010, 02:27 PM   #9
andrewmp6
My brothers 02 f150 going from stock to a 31 he lost 1mpg but he went like 2 or 3 inch taller tires.
andrewmp6 is offline   Reply With Quote
Old 02-08-2010, 02:54 PM   #10
nzjkb5
There is a little more to it than just the diameter. As somebody else mentioned, a wider tire generally will increase rolling friction somewhat, and if you really want to get technical, aerodynamic drag will increase too! But also the tread compound, possibly the tread pattern, inflation pressure - there are a lot of variables. I imagine when the 02 F150 went from stock to 31" tires, they also got wider and probably were made of a softer compound. Also, if the the F150 owner was relying on his truck's odometer for his mileage calculation, it would be off.
I won't bore everybody with my calculations, but ALL THINGS BEING EQUAL (which they probably won't be), I would expect you to see about a half mile per gallon increase on the highway when changing from your 245/75/16 to a 235/85/16.
nzjkb5 is offline   Reply With Quote
