02-07-2010, 10:07 PM | #1 |
2 speed column, with 3 spd
Hey guys, im sure alot of you guys have had this problem. My 64 has a powerglide column, and i installed a th400. id like to keep it on the tree. is there a kit out there to remedy it or do I have to change the column OR should i just get a lokar floor mount. And! are those any good? any help would be app!!
02-07-2010, 10:48 PM | #2 |
It's Better With Nitro
Re: 2 speed column, with 3 spd
There shouldn't be anymore lockout detents besides the P to R, so the column shifter travel for the 3rd gear should not be an issue.
02-08-2010, 12:42 AM | #3 |
60-66 Nut
I've done the same swap you did.....TH400 with a PG column. I didn't do any modifying to it at all and it works just fine. It just doesn't show as having L2 and L1. These trucks did come with Th400's but I don't know if those shift indicators are available. I've not looked since mine doesn't bother me as it is.
02-08-2010, 12:59 AM | #4 |
Thanks for the info guys. Itll save me some bucks which will go elsewhere on the truck
