Need measurement on stock shackles
Hey guys,
Just got my truck friday (YAY!) The truck was lowered all around but dont know how much. Drop shackles were used in the rear but I dont know how much of a drop. Whats the stock shackle length vs. a drop shackle? Also is there anyway to tell how much drop was made up front with springs? |
Re: Need measurement on stock shackles
bump
shackles usaully give you a 2 inch drop. maybe a picture of the truck will help us deterrmine the front drop.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
So shackles are mainly 2inch drops? I will get some pictures on a level surface, Looks like some leafs were also removed, I only have 5 of them isnt there usually 8?
mine only has 4 leafs, and i didn't remove any. so i'm assuming your truck came stock with a 5 pack of leafs. but pictures will help a bunch
Insert Witty Text Here
I would suggest that you check for a suspicious looking bend at the back of your leaf spring. Most lowered trucks I see around here have been lowered by heating and bending the eye down at a 90 degree angle. I wouldn't drive anything with a spring that had been heated and bent.
Slonaker |
anyone heating a leaf spring to lower a truck needs to....never mind i will be nice.
I will check for that bend, I dont remember seeing one but will double check.
Will upload pictures hopefully this weekend if it isnt raining. (100% rust free and dont want to drive it in the washington rain!) |
Heres a side shot of the truck, It was hard to take, was at the car wash up against a wall and people needed by couldnt get a better one. Just click on it to enlarge
![]() Last edited by muthstryker; 02-16-2010 at 12:06 PM. |
Your truck does not look like it is lowered. The tires look to be shorter than stock. I'll try to remember to grab a measurement on a shackle for you though. I probably won't be until tomorrow.
I can still count my vehicles on two... wait three hands. |
So crawled under the truck and started looking around, I think its down 2"s all around. The bed braces? I think, that sit above the shackles have been cut to allow a "taller?" shackle to have room. I will upload some pics tomorrow, going home to take my tow package off.
heres the tire sizes Front 255/60/15 Rear 275/60/15 they are 27-28inches tall.
#13 |
The amount of leafs depends on the truck, I think there are at least 3 different ones. Not 100% sure but I think 4,5,7 and and possibly more for bigger trucks. I have my springs sitting next the my shop I'll measure them in the morning for ya.
#14 | |
Counted my leafs last night, there are 4, dont know how I counted 5 the first time..... Took a shop light and crawled under the truck, amazed at how clean it is... its almost spotless. |
#15 |
I checked mine and the stock shackles are 41/4" center bolt to center bolt.
#16 |
#17 |
#18 |
Ya my shackles are 6 1/2 from bolt center to bolt center..
