02-08-2010, 03:32 PM | #1 |
bbadfred
Lq9 stock intake tube
Does anyone know what the apendage on the underside of my lq9 intake tube is for? My gm mechanic friend thinkes its to supress intake air noise? I want to remove it but won't if it will hinder performance.
02-08-2010, 03:42 PM | #2 |
Gearhead
Re: Lq9 stock intake tube
Im not 100% sure, but I would agree with him, I think its just a silencer chamber to curb intake noise. All the aftermarket intake systems eliminate this "chamber" and use a straight flow tube whenever possible. I would just purchase the Airaid MIT for the vehicle you need and go for it, or you can just make your own tube.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
02-08-2010, 03:48 PM | #3 |
bbadfred
I am using the stock intake tube to clear the stock clutch fan and hoses.
02-08-2010, 03:59 PM | #4 |
It's just for noise cancellation, you can cut it off without causing any performance issues, but you will probably find out that nothing is going to stick to the plastic that the tube is made of, so patching the hole won't be as easy as you might think. Personally, I'd leave it, you can hardly see it on my truck, or do as suggested and get an aftermarket one.
02-08-2010, 04:12 PM | #5 |
bbadfred
Thanks guys! this is the greatest forum on the internet where a person can get answers for most everything!!! I am going to look into aftermaket, is there one made with the flat area on it? I have a friend with a plastic welder who said no problem welding it.
02-08-2010, 04:35 PM | #6 |
bbadfred
Just looked up the Airaid mit tubing and that could work also. Thanks again for the responses. I did not know about Airaid!
02-08-2010, 05:03 PM | #7 |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-08-2010, 11:27 PM | #8 |
the boat guy
eh just put an eletric fan on it and go for the cheapest aftermarket intake you can find. easy to set up and you can blame it on the persuit of power.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-09-2010, 12:29 PM | #9 |
bbadfred
I am being a cheap skate, I already have the clutch fan and don't want to buy a electric fan!!!
02-09-2010, 01:16 PM | #10 |
Gearhead
I would leave the stock arrangement from my experience as well, I have had my fair share of problems with non-factory electric fan set-ups, and (IMO) they CANNOT pull the same CFM that an engine driven fan can pull. The Airaid stuff is very high quality and I used to sell the crap out of it at my previous job, you wont be disappointed.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 02-09-2010 at 01:17 PM. Reason: text |
02-09-2010, 02:07 PM | #11 |
I used my stock radiator on my ls swap and purchased a 95-98 v6 f**d contour Mur***y mistique dual fan ( new $100, used $30.), a dual fan controller (Torqflo # 733647 ( orielly $35.00). the dual fan will pull 3400cfm, better than most electric and all mechanical fans that I am aware of, and no hp robbing.
02-09-2010, 02:46 PM | #12 |
Sorry to hijack, but where can you get this fan new for $100. Thanks. And I used the tubing from intaketubing.com also for my 5.3 conversion.
