radio antenna
Hey guys I put an aftermarket replacement radio in my truck, everything is hooked up correctly, but it gets awful reception. The radio is one with knobs that are made to look like a factory replacement. The truck had an A.M. radio from the factory and I am beginning to wonder if the antenna that is on the truck is for A.M. only and not helping the F.M. signal? Has anyone heard this?
Re: radio antenna
I wish someone knew the answer to this...I was wondering the same thing:
Will the antenna that came originally hooked to a AM only radio work on an AM/FM radio?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Re: radio antenna
I have a CD player hooked up to my original antenna and the FM works fine.
Re: radio antenna
I wish mine worked ok, but I am getting a signal but it is going b/w stereo and mono and driving me crazy. I guess I just need to try an aftermarket one to see if it works.
1972 Chevy SWB - ZZ4 crate motor, 700r4, makes lots of noise! - SOLD 1987 Chevy SWB - SOLD 2000 Chevy SWB - 6.0L heads, Lunati cam, Whipple supercharger, 3.73 posi, caltrac traction bars, headers, custom tune and Borla race muffler. 500 H.P. 1970 Oldsmobile Cutlass 442 w-30 - original ![]() ![]() |
Parts and more parts
Re: radio antenna
Do your radios have an Antenna Trim screw? Some radios have a pot in their electronics that can be "Tuned" in for the antenna towork effectively. However, I have swapped radios and never changed the antennas, before---W/O issue. If you are curiuos swap out the antenna, It is possible that your new radio is more sensitive to any faults that you may have on the old antenna.
Frank |
BOHICA
Re: radio antenna
Don't know if this helps, but our stereo in the shop has an aluminum antenna and occasionally it will fall over and touch the track for the garage door. We found if the antenna touches anything BUT aluminum it will mess up the reception. I know that its not a car stereo, but maybe there is a crack or a bare spot in the antenna wire that is touching steel somewhere under the dash.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
