02-08-2010, 06:53 PM | #1 |
Never Satisfied
Wondering how hard to make my '86 2wd a 4wd
I have a totalled '73 4wd blazer. I just bought a '86 2wd silverado in amazing shape. When I say no rust, I mean no rust. How difficult would it be to convert the '86 into a 4wd.
My thought process is that the rims on the blazer are new. Just before Christmas I picked up a brand new 4 inch suspsension lift. I hate letting all that go. Last edited by bigdnew; 02-08-2010 at 06:53 PM. |
02-08-2010, 07:11 PM | #2 |
Re: Wondering how hard to make my '86 2wd a 4wd
i want to do the same thing to my c30. Get axle, 4wd tranny transfer case leafspring hangars. only thing if the crossmember you will have to custom fab. At least thats what's going to have to happen on my c30. I dont know if stuff from the blazer will bolt up to your truck tho.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
02-08-2010, 07:40 PM | #3 |
Robert Olson Transport
people do it all the time on here so im thinking its not that hard. You will prolly need a different set of driveshafts or at least have some made
02-08-2010, 09:34 PM | #4 |
Google B52 kit, that is the route that I am going to go. It seems that is what everyone does, using rear leaf springs for front gives a lot better ride and more wheel travel, oh and much stouter leaf mount!
02-08-2010, 09:47 PM | #5 |
I used the B52 kit, but using stock style front springs. Mounted in the rearwardmost hole, they are still 3-4" forward of stock.
Depending how bad the parts truck was wrecked, you could use just about all of it for parts to swap over. It's not really hard, but it is time consuming.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-08-2010, 10:07 PM | #6 |
Why are they forward? I thought it was stock placement unless you reversed it or something? Does the B52 kit always move the axle forward? Thats not cool...
02-08-2010, 10:15 PM | #7 | |
http://diy4x.com/cart/index.php?rout...product_id=121
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
02-08-2010, 10:29 PM | #8 | |
Never Satisfied
02-08-2010, 11:28 PM | #9 |
I know that the B52 kit uses rear 1\2ton springs, what I don't understand is why the front axle is moved forward. From the info I have gained on this kit is that the some guys liked it moved forward to lengthen wheel base for wheelin'. So does this kit move the front axle forward or is it stock location???
02-08-2010, 11:54 PM | #10 |
The kit IS designed to use 52" springs, but when I talked to Kurt @DIY4X he said that you can still use stock style 48" springs, just that the axle will be farther forward than stock. This isn't really a bad thing, you want the axle farther forward to keep the tire from hitting the firewall when compressed.
I had the 4" 48" long springs, so used what I had. I might go bigger with the truck, so either going with 8" 48" or 4" 52s, whatever I can find. Also, these aren't stock replacements.....
02-09-2010, 09:18 AM | #11 |
Never Satisfied
bump
02-09-2010, 09:40 AM | #12 |
Remove and reuse these parts from the Blazer
Front Spring Hangers front/rear Axles Tranny/Transfer case Front driveshaft Tranny/Transfer case crossmember steering box/draglink sway bar frame mounted upper front shock bracket You'll also have a 3" difference in the rear spring hangers going from a 2wd to 4wd which you could make up with a shackle flip/block or source 4wd pickup rear spring hangers, since the K5 hangers are not the same as a pickup. The 4wd engine crossmember is not a direct fit into the 2wd frame (too tall)so you'll have to do some fabrication/modifications.
05 1500 Crew Cab 79 K10 Scottsdale 71 K10/Custom 85 K30 CrewCab 72 Camaro |
