Old 02-09-2010, 01:39 PM   #1
xJoey Dubsx
xJoey Dubsx's Avatar
Best frame for swapping a 51' GMC 3/4 ton
51' GMC 3/4 ton with the 8' bed, what would be the best option for a 2wd frame swap to bag?
Just kicking some thoughts and options arounds...
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
Old 02-09-2010, 02:23 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Best frame for swapping a 51' GMC 3/4 ton
s10 frames are popular with the AD group.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-09-2010, 02:47 PM   #3
southbounddee
southbounddee's Avatar
if you have a long bed you could use a S-10 extended cab frame,or use a short cab long bed frame and chop your bed 9''
southbounddee is offline   Reply With Quote
Old 02-09-2010, 03:32 PM   #4
xJoey Dubsx
will the ext cab be the right size, or will that need chopped/sectioned?
Old 02-09-2010, 04:12 PM   #5
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Your stock wheel base is 125.25 inches. The extended cab S-10 is 122.9 inches. To use that frame you have to change something.
Easiest answer might be to move your rear fenders forward until they are centered over the rear wheels. Otherwise its cut down the bed or lengthen the frame.
Steve@OldSub.com is offline   Reply With Quote
Old 02-09-2010, 05:04 PM   #6
BlueJeep
BlueJeep's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=384736
And if it's a 3/4 ton the bed isn't 8 foot, it's more like 7'4".
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-09-2010, 05:18 PM   #7
Dan Bowles
AD Addict
Don't forget a Dakota. Easier to deal with the radiator with the rack & pinion, its wider than the S10 track so no spacers needed.
I was going to do one until I got a hell of a deal on the S10 I'm using this time around. I've got another truck body so I'll keep an eye open for a Dakota.
Dan Bowles is offline   Reply With Quote
Old 02-09-2010, 05:19 PM   #8
Dan Bowles
AD Addict
Oh yeah, and you can change the Dakota to 5 lug and use Ford/Dodge bolt pattern wheels on the front by simply using the old discs. You'll want to change to a Camaro/Ford 8.8"/9" rear end for width anyway so you can target a 5 on 4.5" pattern there, too.
Old 02-09-2010, 05:57 PM   #9
xJoey Dubsx
My Dakota ain't going to be the donor! Although it's already bagged!!!!
I bet S10 beds are cheaper and easier for air ride.
Old 02-10-2010, 10:57 AM   #10
1952ssr
1952ssr's Avatar
If you did a S10 x-cab frame and bagged it you could do a four link or simular set up in the back and extend or place the arms back that extra 3 inches. That should work.
1952ssr is offline   Reply With Quote
Old 02-10-2010, 11:07 AM   #11
xJoey Dubsx
I'd probably be doing the ART or SD kit.
