Master cylinder Paint
What have you used to paint your master cylinder and booster pump?
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
Re: Master cylinder Paint
I don't know what everyone else does but I have an old, cast master cylinder reservoir that I'm going to try gun bluing.
Any thoughts on this? |
Frequent Flyer
I know it is not actually the correct original finish but I painted mine with a Cast Paint...
![]() Join Date: Mar 2009
Eastwood Co. just came out with a paint made specifically for master cylinders and boosters.
i've used POR15 with very good results
SWB 4x4 Collector
![]() Join Date: Jun 2001
Depends on what your booster is for color. A/c Delco's were cad plated, while the other brand (which slips my mind) was black. That is the 2 colors from factory. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Bendix is the other brand.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Moderator
![]() Join Date: May 2007
x 2. I have it on the master cylinder and every other engine part in my daily driver. 4 years later, it still looks new.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
SWB 4x4 Collector
I have some POR and love the stuff. I thought the brake fluid would eat it. I will give it a try. Thanks BTW I have a Bendix.
Grandpa in the rustmobile...
you guys swear by por15 may have to try it..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I sprayed mine with clear paint to keep the cast look without rusting.
#13 |
I've always used rattle can
#14 |
"THE GREEN GOBLIN"
I used Por 15 and I had a leak now the paint is gone on both ends of the Master cylinder so I personally think It does not stand up to the task Brakefluid is some strong Sh##. Now I believe Tx Firefighter had mentioned he powdercoated a couple of them with good results. you might want to look into that I think thats what I might have to do..
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#15 |
Powder coating is great. However, it took me enough time to get the brakes right that there is not way I am taking the thing off my truck. I like the idea of clear. I will have to see what I am in the mood for on the day I decide to do it.
#16 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Powdercoated master cylinder
![]() Unfortunately I had to clean and paint the prop valve since I can't coat them.
#17 | |
I have heard that "wrinkle paint" is impervious, but never tried it.
1968 LWB C20 / AC / Wood Bed |
#18 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Powder coated MC. Done 8 months ago & no peeling.
http://www.67-72chevytrucks.com/vboa...d.php?t=349845
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#19 |
I use the Duplicolor's Engine enamel and it works great for the master and calipers since it has ceramic coating added to it.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#20 |
Now that you mention it, I do remember reading that ceramic-based coatings will hold up. Again, haven't tried it.
#21 |
Spanked once
![]() Join Date: Oct 2006
On my 71 project everything is new and I used silicon fluid. Don't know if you can flush and fill or not but it won't peel paint.
The ole 350 budget build. |
#22 |
Best idea I've heard yet!
#23 |
Might want to think twice and do some research before you commit to the silicone fluid. The "resto" people seem to like it - most likely because it helps avoid "oops" drips = damage on expensive paint jobs.
When I went to stainless lined bores on Vette disc brakes many years ago, the 'experts" that sold me the calipers almost insisted that I use their pricey silicone fluid. I thoroughly cleaned and flushed every last line and component (denatured alchohol) and went with silicone. Some time later, when leaks started and I wound up going through all four calipers and the lines, I found cruddy/grainy/goopy stuff in there. Called the "experts" again down there in Florida (the stainless bore guys) and they said "Oh yeah, we are familiar with that problem" and then informed me that they had "changed their minds" about their silicone recommendation and that I should go ahead and use regular DOT whatever. Of course, they also offered to take all four of my goopy/messy calipers and send me four clean stainless type rebuilds (again) - for a VERY hefty price. After that experience, I am running DOT whatever just as in all of the other Chevs/GMCs here, that do not leak and are clean.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
#24 |
My son painted the booster with base coat, clear coat paint. I painted the master cyl. with black engine paint.
#25 |
Tot Roddin'
I used cast iron colored paint from O'Reilly; the vendor is escaping me... turned out great and any touch up I needed to do was easy.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
