02-09-2010, 03:28 PM | #1 |
The Beach Cruiser
misfire/rough idle/lack of power
99 silverado 5.3l
I started it the other day and it felt like it had half power. It would idle at 500rpm. When I speed up it would sputter and I could hear popping in the intake area. I turned it off and restarted it again. It ran fine. Today it did the same thing. I turned it on and off several times before it was back to normal. I checked all the connections I could see. I'm guessing something in the computer is not connecting every time I start it. Any idea where to start? Thanks
1999 Silverado DD 1966 Panel Truck 2003 Harley Road Glide 1967 Schwinn Tandem Single Speed |
02-09-2010, 07:04 PM | #2 |
Re: misfire/rough idle/lack of power
MAF Sensor dirty?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
02-09-2010, 11:13 PM | #3 |
Is the check engine light on? I have seen a few trucks and vans with 02 sensors causing misfire problems.
70 C10 SWB stepside forsale 00 Silverado Z71 Sold 95 Eagle Talon TSI turbo (Hellz ya its fast) 70 Chevelle 69 firebird 10 Silverado 4x4 |
02-10-2010, 07:35 AM | #4 |
The Beach Cruiser
Check engine light never came on. Yesterday I went across some train tracks and it sputtered and popped . I got it home and went through all the connections I could see. Unplugged and plugged all I could find. Started it up, same issue. Turned it off and restarted it, works fine.
02-10-2010, 12:36 PM | #5 |
Check the fuel pressure, Key On Engine Off 55-62 psi.
