02-09-2010, 03:34 PM | #1 |
Need help placing axle on 66 c10
I stripped my frame down to bare and cut out the drive shaft safety loop cross member and now I can not figure out where to place the axle. I still have the shock cross member and pan hard bar cross member in. Is there anybody who has measurements from some where on the frame?
02-10-2010, 12:04 AM | #2 |
60-66 Nut
Re: Need help placing axle on 66 c10
If your truck is a shortbed measure back 115" from the center of the front wheels back to the center of the rear axle. If your truck is a longbed that measurement is 127"
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-10-2010 at 12:05 AM. |
02-10-2010, 12:41 PM | #3 |
Thanks you are the man. I will post some pics of all the new tubular crossmembers when im done.
