Lt1 Swap
just crashed my impala ss and thinking of swapping it on my 64. but have no idea were to start. any ideas.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Lt1 Swap
look for Thealien's write up, also see ls1tech.com, ls1truck.com
They will be your best bet to start with.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Jan 2010
Re: Lt1 Swap
Re: Lt1 Swap
Start
HERE
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Lt1 Swap
thanks every one.
Re: Lt1 Swap
Did you click on the word HERE in my last post? It brings you to a site called LT1swap
I believe the LT1 still uses the three bolt SBC motor mount? But I could be mistaken.
Re: Lt1 Swap
I just put a 95 SS LT1 in a 63. The straight 6 engine mounts bolt right up. All you need to add is a tubular trans mount unless you have an auto already. Then I think it may be just sliding it back. At that point it's physically in the truck. The remainder comes down to plumbing wiring and a driveshaft. These are the steps I'm working on now.
I've chosen to strip down the harness myself rather than spend 400 bucks on somebody's plug and play version. I'm going to try using the caprice tank hung behind the axle. The other option I looked at was a large semi filter as a remote sump and a 2 external pump system allowing me to reuse the trucks stock tank. (Google search for EFI Ford Broncos.) That's where I was looking at parts for that. For cooling I'm looking at a stock camaro radiator like most of the guys on here seem to lean toward. (The impala one won't fit.) The rest of it seems pretty straight forward. No offense but the LT1swap.com seems highly lacking in info to me. Then again I've had the LT1 in and out of my car a number of times so maybe I covered the basic on my own already. I should really start a build thread of my own. I hope to get the truck indoors this weekend and so I'll be able to start making progress again. - Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. Last edited by sshockr; 02-09-2010 at 07:24 PM. Reason: More info. |
Re: Lt1 Swap
LT1 is a second gen sbc. Your swap is easy. remove all water and vacuum hoses, electrical wires, and transmission. unbolt motor. pull motor. insert lt1. work in reverse until you're burnin rubber
'64 4x4 Stepside 350/sm420, going L92 in the near future '05 GTO that gets more attention than my truck '69 Jeepster Commando that needs more attention than my truck '71 wagoneer that gets less mpg than the gto |
Re: Lt1 Swap
Re: Lt1 Swap
nomrlz, are you over on the Impala SS forum too?
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
Slots go on anything!
Re: Lt1 Swap
I have one in my '79, and I really like it. Brendan at LT1swap.com is very reasonable on his PCM tunes, I plan sending him mine when the time comes. Mine was started by someone else, I bought it as a project with a rats nest of wiring. If you can lay the harness out first, it should become pretty apparent which wires can stay or go. Download the PDF instruction manual at the Painless website, that will help it make a lot more sense too.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: Lt1 Swap
Hotrodlane.cc is the website I used when I put a LT1 in my 67. Street and Performance in Mena, Arkansas has done alot of these. I have one of their LT1s and a 4L60E in my truck. It is wicked fast. And believe it or not was pretty straight forward once you got the wiring right. They have the wiring diagrams online. One thing of note though is that I had to put a late model Camaro radiator in it. And used the water hoses that go with it.
Good luck. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
#13 |
Re: Lt1 Swap
#14 |
Re: Lt1 Swap
Thought I recognized the screen name.
Here's my LT1 in an mounted. ![]() - Brian
#15 |
Re: Lt1 Swap
amazing how low that looks in there
#16 |
Re: Lt1 Swap
What motor mounts and brackets did you use for the LT1?
#17 |
Re: Lt1 Swap
If you are not going to run the A/C compressor (or are going to use an aftermarket A/C bracket) you can use the same mounts as a normal SBC. The right side has to be moved back to clear the stock compressor.
#18 |
Re: Lt1 Swap
I'm running an AC delet pully and I notched the frame to clear even that with the B-Body accessory brackets.
Mounts are stock I6 location I6 rubber. No modification neccessary. On the transmission end I have a Bowtiebits Tubular Crossmember. I went with them because they're just up the street from my house. It's like shopping at a regular parts store. - Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. Last edited by sshockr; 02-11-2010 at 09:16 AM. |
#19 |
Re: Lt1 Swap
that looks really good in their... i was told by my neighbor that you can use the engine mounts of a 85 style c10 to put the lt1 in their....
#20 |
Re: Lt1 Swap
sshockr, what are you going to use for a throttle cable? I have an LT1 I want to put in my 65 one of these days.
#21 |
Re: Lt1 Swap
I used a Lokar setup. Straight forward install.
Kerry
#22 | |
Re: Lt1 Swap
- Brian
