Heater problems
I have a 85 GMC i get no heat from the defroster just blows cold air! can someone tell me where to start.
![]() Join Date: Nov 2009
Re: Heater problems
Check Coolant level, thermostat, heater core, heater door
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Heater problems
i posted pictures a couple of weeks ago in another thread similar to this with the location of the heater door and the cable if it turns out to be the problem
78K & 79C Jimmys
Re: Heater problems
Check this clip and the cable above it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 02-10-2010 at 02:33 AM. |
Re: Heater problems
Thanks to everyone and the pic!! I will start on it tomorrow. I will let everyone know how it goes.
Re: Heater problems
I replaced two thermostats in a 4.3l V6 due to heat probs, didn't fix a thing. Repaired the broken cable end and heat would run you out!!!!!
One shot, one kill.
Re: Heater problems
Attack this issue 1 step at a time. Check coolant level. Next run engine for 20 minutes and feel upper rad hose, should be HOT. If not, change thermostat & recheck. (coil spring end towards eng, no spring end towards rad) Next feel heater hoses. If one is cold and the other hot, heater core is plugged. Try flushing it out. If that don't work, replace it. Lastly, check door operation. Hope this helps, Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Re: Heater problems
So how did it go you get it fixed O and Thanks OLD RUSTY you helped me out the other day on that other thread you were talking about my computer thing above the heater was blocking it from giving me heat (who knows how long it was that way the po said it was years since the heat work) sa again tons of thanks o and my wife thanks you too
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." |
