02-09-2010, 06:38 PM | #1 |
Door window seals too short?
I got a set from LMC and they seem too short. They barely touch the window and don't really seal at all. Is that common? It seems like the rubber should be at least 1/8" longer.
02-09-2010, 08:48 PM | #2 |
Re: Door window seals too short?
Usually this problem shows up when the door is spread apart. If you have a 71 or older check to see that the sheet metal strip between the two halves of the door is intact. (the strip is toward the front of the door close to the window run).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-10-2010, 02:25 PM | #3 |
Will do. Thanks Jim!
02-10-2010, 02:32 PM | #4 |
Between Trucks...
I had those LMC seals and they rotted out in a year. Got some good ones from Wes at Classic Heartbeat.
Beat it to fit, Paint it to match... |
