02-09-2010, 07:24 PM | #1 |
Wood Bed Options???
71 Fleetside LB
I live in Alaska so shipping to here is usually very expensive. I need to replace the stock wood bed in my truck. I got a quote for a pine board complete kit with SS hardware for $475 but the shipping is $271 which is actually discount they gave to me for a total of $746. I'm looking for advice/options that others have done that would be much cheaper. How about just bolting in some marine grade plywood sheets cut to fit? Ugly, I know, but should last awhile. I guess I could try to clean up the original steel strips but they are very rusted and got pretty beat up when I took out the bed. The original wood isn't in very good shape either. Any suggestions? |
02-09-2010, 07:49 PM | #2 |
member #16
Re: Wood Bed Options???
Heres some wood info from gmc pauls. Probably cheaper to get the wood cut local.
http://www.gmcpauls.com/47-72_BedWood_Info.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
02-09-2010, 08:17 PM | #3 |
I've known people to use marine plywood that was very funcional & looked good too. I've seen it used in strips & also out of 2 4x8 sheets contoured to fit. It doesn't make sense to me to spend that kinda money if your going to use it like a truck anyway. A boardmember from nevada used two sheets of oak plywood & it looked pretty darn nice. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-09-2010, 08:26 PM | #4 |
Someone on here made the permanent decking into their bed wood strips. It looks nice and can really take a beating.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
