02-09-2010, 09:08 PM | #1 |
Roadtrip!
Engine ID please.
Parting a 68 right now that has a 327 listed on the spid in the glove box. The block casting numbers are 3914678. That could be a 302, 327, or 350 from 68-79. the intake is 3927184 which comes up as a 68 350 car only. The block pad numbers are VO705YV
Can i get some ideas from that? I thought all trucks had a "T" in the sequence. Everything appears original on it yet right down to the TH400 kickdown on the carb. Thanks for any help, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-09-2010, 09:30 PM | #2 |
Re: Engine ID please.
68 327 220hp manual trans
http://www.chevy-camaro.com/chevy-ca...es.asp?group=7 Scroll down. A search for Chevrolet smallblock suffix codes brings up more info than a sane person wants to deal with. Last edited by mr48chev; 02-09-2010 at 09:43 PM. |
02-09-2010, 09:42 PM | #3 |
Thats what i got to. 68 327
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS |
02-09-2010, 11:44 PM | #4 |
Roadtrip!
The truck is a 68 and 327 is on the spid. However, the truck has an auto trans with the kickdown on the carb for a th400. I can't tell the engine has been replaced, but who knows. The trans was replaced from a 400 to a 350. So is this a truck or car engine. Also what is up with the bypass from the water pump to the intake? Thanks
02-10-2010, 11:47 AM | #5 |
It looks like the engine could be original, YV translates to 68 327 with manual transmission in a C-10, 220 hp with a 4 bbl carb. someone hooked a hose into the temperature sending location on the intake manifold. Not sure why as I don't see any reason for doing it. Also, the heater hoses look a little different!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 02-12-2010 at 09:06 PM. Reason: spelling |
02-10-2010, 12:00 PM | #6 |
mine is a 68 327 and has (had) the smae bypass hose... V0405YX (240HP)
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-10-2010, 06:10 PM | #7 |
Roadtrip!
So would we think the engine was replaced since it has an auto trans? I don't see any clue that it ever had a clutch. It still has the original plastic clutch delete even.
JimK, that is an old style hose heater and actually runs under the engine also. I have to look that mess over better... So any ideas on the bypass hose??? Thanks for the info so far, Eric
02-12-2010, 09:05 PM | #8 |
I looked up the suffix code "YV" on GMC Pauls listings and it says that the engine is a 240 hp, with 4 bbl and had an automatic 3 speed transmission in it. Since your truck has an automatic and it has no signs of ever being a stick, (including the very rare plastic clutch hole block off plug), I have to believe that it is the original engine and transmission. If you will get the numbers off of the transmission, I can probably come up with information on it. (There is an aluminum tag on the side of the transmission that will have stamped codes on it. I believe the tag is on the right as I remember.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-12-2010, 10:18 PM | #9 |
Roadtrip!
Jimk, that makes more sense for what you found. Unfortunately, i know the trans has been replaced with a turbo 350. I appreciate the help. Eric
02-13-2010, 05:44 AM | #10 |
Active Member
Eric are you selling the motor?
02-13-2010, 11:32 AM | #11 |
Roadtrip!
I guess i would for the right price. Was told it ran fine. I cranked it over until it had good oil pressure before i started parting it. The gas was bad so i didn't try to get it running.
04-05-2010, 09:22 AM | #12 |
The manifold number is the same on my 69 3/4 ton which I am looking for a new manifold for which led me here.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
