Old 02-09-2010, 11:05 PM   #1
Tezjoe84
Tezjoe84's Avatar
Header Compatability
I'm just curious, I've done some searching and cant find much... But what other make/model of cars/trucks headers are compatible with our trucks. I'm looking for a decent price of coated headers with 2 inch primaries.
Hooker sells some for our truck, Super Comp for over 700 bucks, and I know they make some for 67-71 camaro that's half the price.. I don't really get why they have to be twice the price for the same size header.
Anyhow, any info would help...
Thanks guys,
Joe
1957 Chevy 3100 Stepside
Tezjoe84 is offline   Reply With Quote
Old 02-09-2010, 11:39 PM   #2
travo77
travo77's Avatar
Re: Header Compatibility
i know 3/4 length chevelle headers are good for lowered trucks
travo77 is offline   Reply With Quote
Old 02-12-2010, 04:19 AM   #3
Tezjoe84
Tezjoe84's Avatar
Re: Header Compatability
yeah I want to run the long tubes, I was just curious if there's any out there for other makes/models that will fit with the 2". because for some reason 2" and over long tube coated headers for our trucks are rough to find. Especially at a decent price.
Joe
Old 02-12-2010, 10:08 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
I have both the Chevelle and Camaro Hooker Competition series headers with the 2" primary.
I think the Camaro ones may work on a 2wd with minor rework for depth of collector. The Chevelle ones have tubes routed around the lower A-arm of the A-body so they may not clear the truck frame.
I have a set of big block headers for our trucks too so I will stack them all together this weekend and take a few pics for comparison.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-12-2010, 10:42 AM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
There used to be a guy on here who ran full length Camaro headers on his lowered black 2WD truck. They tucked up very nicely inside the frame rails, but he had to build a custom transmission crossmember to get his exhaust to clear everything. You might be able to find some info about it by doing a search. I can't remember his name on the board, sorry...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-12-2010, 12:58 PM   #6
68 TT
68 TT's Avatar
Slonaker
That's good to know they clear the floor pan un-modified. I was worried they would run into the floor and need major rework just to get them low enough to work. A trans crossmember is easy to build relative to the mods needed to lower header collectors.
I bet a first gen Camaro trans crossmember would work great and could be just the right width. I will take a look at this this weekend and see.
Old 02-12-2010, 01:19 PM   #7
Slonaker
Slonaker's Avatar
Unfortunately I don't remember any details like brand or any other problems he might have had (like shifter clearance). Don't spend any money based on an old man's memory.
I did several searches, but couldn't find anything. Hopefully someone else remembers the guy, and can give you better info.
Slonaker
Stock '01 Silverado
Old 02-12-2010, 01:31 PM   #8
Alex1
Alex1's Avatar
$700.00 is a decent price for full length coated headers with 2" primaries. Are you sure they're1/2 the price for another model vehicle?
Alex1 is offline   Reply With Quote
Old 02-12-2010, 01:34 PM   #9
68 TT
68 TT's Avatar
Slonaker
I already own all three sets of headers but don't have a truck with a big block any longer to test them on.
If I can get my spare heads back from a friend I will mock it up this spring when I am putting my C-10 back together and see how they fit.
Old 02-12-2010, 01:40 PM   #10
68 TT
68 TT's Avatar
The 2" primary Hooker Competition series headers are $166 for Camaro's & Chevelle's. I own both sets and they fit great.
I wouldn't pay the $205 more they want for coated ones. You can have it done for half that.
http://www.summitracing.com/parts/HOK-2455HKR/
Old 02-12-2010, 01:59 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
^wow that is cheap.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-12-2010, 02:32 PM   #12
Alex1
Alex1's Avatar
Those are competition headers - The 2" for trucks are Super Comps -and they cost more.
http://www.summitracing.com/search/P...r+comp+headers
Old 02-12-2010, 02:51 PM   #13
68 TT
68 TT's Avatar
I originally ran a set of super comps in a big block 87 Monte Carlo I had then built another similar 79 Malibu with modified Chevelle competition headers in it instead.
I don't think the difference in performance is worth the $350 more they cost if we can make a set of Camaro competition series 2" tube headers fit.
99% of all street driven big blocks don't need more than 2" primaries and many with the smaller stock valve sizes would benefit from smaller primaries than that.
I ran 1-3/4" tubes on a 3900 pound 70 Chevelle with an evil 427 that ran 11.70 ET's on hard compound street tires. That took around 500 rear wheel HP to do so you can build some decent power with smaller tubes than 2".
Old 02-12-2010, 04:56 PM   #14
Slonaker
Slonaker's Avatar
The truck i was talking about was a smallblock...
Slonaker
Stock '01 Silverado
Old 02-12-2010, 05:01 PM   #15
68 TT
68 TT's Avatar
Slonaker
Same should apply for the big block as they still have to fit into the same restricted space and ground clearance of the Camaro.
Old 02-12-2010, 05:11 PM   #16
S10Fan
Old Heap Driver
I'm waiting for someone to post pictures of their BB 2WD truck with Camaro/Chevelle full length headers. I seem to remember another thread recently where the poster said the Camaro/Chevelle headers wouldn't fit on his truck.
I want to install headers on my truck but I need the ground clearance. The shorty headers I've priced seem way high vs a set of full lengths. Performance isn't an issue for me since my BB is a bone stock peanut port motor home engine. The headers for me will be purely for looks.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-12-2010, 05:24 PM   #17
68 TT
68 TT's Avatar
In that case I had these on my 67 C-10 when it had a 396 in it. They fit fine with plenty of ground clearance and are supposed to fit a square body too.
http://www.summitracing.com/parts/SUM-G9011/
Old 02-13-2010, 08:00 AM   #18
S10Fan
Old Heap Driver
Thank you.
My concern would be do they hang below the frame rail, if so, how much? I'm running airbags and I like to lay it out when parked.
Shorty headers would be a solution to my problem but i refuse to pay double the price for half the header. LOL.
Bryan
Old 02-13-2010, 11:30 AM   #19
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: Header Compatability
I am going to try out a set of Thorley BBC Tri-Y's on my 73 3/4 496 truck.
We are going to install these next weekend, if everything works out right for me.
I will share some images after the system in installed.
Link:
http://67-72chevytrucks.com/vboard/s....php?p=3783775
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 02-15-2010, 11:45 AM   #20
68 TT
68 TT's Avatar
Thank you.
They did hang below the frame rail about 4 inches. Just enough to run side exit tail pipes in front of the rear wheels.
Probably too much for what you want to do but for a stock height or just slightly lowered truck they would be fine.
You could always build your own shorty headers out of a set of the Summit long tubes and some 1-3/4" mandrel U-bends.
