02-09-2010, 11:26 PM | #1 |
Not Mine But A beauty
GUys Runing 4 wheels disk brakes in here please!
I'm about to do the 4-wheel disc brake swap and im wondering what master cylinder you guys are running and if running a disc/disc cylinder is a prop valve still needed?
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
02-10-2010, 12:34 AM | #2 |
can I tuck tractor wheels?
Re: GUys Runing 4 wheels disk brakes in here please!
x2
My build page.... http://67-72chevytrucks.com/vboard/s...d.php?t=347666 |
02-10-2010, 01:29 AM | #3 |
Mid 70's Corvette master cylinder works well.....and yes, you should use a disc/disc proportioning valve.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
02-10-2010, 01:32 AM | #4 |
TOTY 2006
I used a mid 80s 3/4 ton truck master cylinder and brought a disc/disc proportioning valve as well. the valve was brought at a GoodGuys swap meet, but I don't remember the maker.
02-10-2010, 02:28 AM | #5 |
i will go with the vette one one problem down does anyone know whre i can get some front disc brake dust shileds for cheap?
02-11-2010, 08:18 AM | #6 |
no one on the dust shields where can i get some
02-11-2010, 08:53 AM | #7 |
Check out Performance online or ECE. I just got my brake booster and prop valve for Disc/Disc from POL. Im not worried about a dust shield though
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
02-11-2010, 11:45 AM | #8 |
theres someone selling a new cpp disc/disc prop valve in the for sale section, I think its titled "suspension parts" I just bought his air valves,
are you changing out the whole rear end or converting your existing rear end to disc?
1967custom |
02-11-2010, 12:04 PM | #9 |
i put a possi rear end from a '96 ss impala with disk brakes in my '72 and all i did was bleed them,works the same as it did before but better!
02-11-2010, 02:21 PM | #10 |
i have a wilwood adjustable prop valve, no sheils and corvette master
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
