Old 02-10-2010, 10:02 PM   #1
RShaips
4WD 3/4 ton axles in a 1/2 ton ?
I have a 72 Jimmy 4WD that I would like to put lower gears in, anyway I found a set of 3/4 ton 410 gears 86 Chevy axles. I would like to keep my six lug pattern, what are my options? Can I use these with different axles? or maybe cut them and weld on my hubs? Any ideas? Or should I just wait until I find some 1/2 ton axles? Thanks
RShaips is offline   Reply With Quote
Old 02-10-2010, 10:07 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 4WD 3/4 ton axles in a 1/2 ton ?
If it was dana 44 frt. it would swap parts real easy, but being an 86', I bet it is a 10 bolt. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-10-2010, 10:13 PM   #3
RShaips
What do you mean swap parts? the axles interchange? with different bearings?
Old 02-10-2010, 11:03 PM   #4
71blksuper4x4
SWB 4x4 Collector
I was always under the impression that the Dana 44 1/2 ton and 3/4 ton were the same axles. The 1/2 ton hubs and backing plates I would think would go onto a 3/4 ton Dana 44. Since those axles you found are out of a 1986, they should be a 10 bolt front, which is a different axle altogether. Up til about 78 or 79 they got rid of Dana 44 3/4 ton front ends and started putting Corporate 10 bolts in trucks. Trevor
TREVOR
Old 02-10-2010, 11:07 PM   #5
Mike C
Mike C's Avatar
He means the entire assembly from hub to hub swapped in. On the rear you need to re-weld the spring perches and swap the 86 parking brake cables for the 72. I did this exact swap on my Jimmy. I highly recommend this as I was hell on 12 bolts.
If you want to keep your 6 lug axles as you mention, you have no choice. The front will be a 10 bolt and gears are not compatible with your Dana 44 and the rear will either be a semi-floating 14 bolt or full-floating 14 and once again, not compatible with your 12 bolt.
Do the swap and buy new wheels and tires. WAY cheaper/easier than paying for gear setup.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-10-2010, 11:17 PM   #6
RShaips
So, if I found some 3/4 ton hub to hub axles that were from a late 70's truck or earlier I could use the 1/2 ton axles to slip in and keep my six lug? I understand that I could switch complete assemblies from the 86 but would prefer to keep my 6 lug Ralley wheel set up, even though the 3/4 ton is cheaper. thanks for the help guys
