02-10-2010, 10:42 PM | #1 |
6 lug disc brakes
i am wanting to do a disc brake conversion on my 69 swb chassis. i have a 5 lug front crossmember, and rear axle from a 79 c10. will the rear end from the 79 be too wide? someone said they thought it was. also does the front crossmember bolt right up, or should i just change over the spindles? one other thing, if i stayed with 6 lug, what parts, and from what, do i need to do 6 lug disc brakes on the front? thanks in advance for the help.
69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 |
02-10-2010, 10:53 PM | #2 |
Grandpa in the rustmobile...
Re: 6 lug disc brakes
I THINK you can just swap balljoints. I KNOW you can do it with 71 72 stuff. But unsure about 73-87 stuff. I know you can swap whole crossmember. May have to drill some new holes.
If your thinking of lowering the front with drop spindes in the future, BUY CONVERSOIN DROP SPINDLES. These will use your existing steeering componenets and existing balljoints. You would have to buy 6 lug rotors/bearings calipers pads and hoses and mc prop. valve.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-10-2010, 11:15 PM | #3 |
Member of the longbed union.
The crossmembers are the same, I would just swap over the control arms and spindle. since the 79 has the never style contorl arm bushings. The rear axle is 1.5" wider per side then the 69 rear. so you will have to have the correct BS rims.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
02-10-2010, 11:31 PM | #4 |
Restoration Virgin!
Les...the front x-member should swap right over...I think you'll have to drill/ woller out like 2 additional holes in the frame....
I asked sorta the same question in this thread....http://67-72chevytrucks.com/vboard/s...d.php?t=381785
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 02-10-2010 at 11:33 PM. |
02-10-2010, 11:42 PM | #5 |
thanks for the replies so far. the main thing im pondering is do i convert to 5 lug disc brakes with my donor parts, or do i leave the 6 lug rear alone, and do 6 lug disc up front. what trucks came with 6 lug front disc that i can get parts for to do this? from looking it seems that disc brakes and 5 lug came hand in hand.
02-11-2010, 12:09 AM | #6 |
only 6 lug that I know that will fit that spindle are some of the 4x4 trucks. There is no reason to swap over your crossmember as long as they are both c10's,, if it's the 3/4 frame then it have 4 bolts that hold the control arms so then you would have to swap. Check your stuff to make sure they both have the u-bolts that mount the lower control arm.
02-11-2010, 12:11 AM | #7 | |
02-11-2010, 12:12 AM | #8 |
Restoration Virgin!
Maybe try and find a 5 lug rear end here locally?!?!?.....
http://charlotte.craigslist.org/pts/1592310107.html see if he will part with the 5 lug rear? http://charlotte.craigslist.org/pts/1594816135.html not sure what it came out of or if its 5 or 6 lug??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-11-2010, 12:14 AM | #9 | |
02-11-2010, 12:23 AM | #10 |
Restoration Virgin!
I live on CL too
Pm returned!
02-13-2010, 09:29 PM | #11 |
Check out earlyclassic.com I think they sell 6 lug disk brake kits. I changed my truck to 5 lug. Got 5 lug rear axles from them. See picture of my 5 lug rear disk.
02-13-2010, 09:35 PM | #12 |
thanks for the info. i was hoping to find stock parts that would work, but im gonna check them out!
02-13-2010, 09:50 PM | #13 |
I bought some six lug rotors an replaced the five lug rotors. I think six lugs look better, also they were a direct replacement . http://www.performanceonline.com/sto...at=1074&page=1
02-13-2010, 09:54 PM | #14 |
here is another company http://www.classicperform.com/
02-13-2010, 10:02 PM | #15 | |
69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 Last edited by lclippard; 02-13-2010 at 10:16 PM. |
02-14-2010, 12:22 AM | #16 |
73-87 but i think the bearings are the same ,
02-21-2010, 11:20 AM | #17 | |
Still plays with trucks
88 to 99 C2500 light duty trucks came with six lug rotors. Use the spindles, rotors, calipers, ball joints and outer tie rods & adjuster sleeves from the C2500 with Moog part # ES2020R/L inner tie rods to convert to the older center link. You will have to cut about 3/4" off each side to make the tie rod assemblies the right width to get your alignment correct. You will need 3/4-ton lower A-arms for the ball joints to fit as the 1/2-ton used smaller diameter ball joints. 67 to 87 vintage will all work. I just started this swap for my 67 C-10 and scored the setup off of a 93 C2500 light duty truck yesterday for under $60. The rotors & calipers fit inside and clear my 15" Cragar Soft-8 rims too. Now I need to get me some 3/4-ton lower A-arms and some front end parts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-21-2010, 11:24 AM | #18 |
68 TT, did you have 71-72 disc spindles before? i was looking thru parts and found these rotors, and im curious if they could be used on the 71-72 disc brake spindles with different bearings.
02-22-2010, 01:21 PM | #19 | |
I saw a thread where people tried what you want to do and the rotor placement was supposedly wrong so the caliper didn't line up with the rotor surface properly. Close but not right. I'm sure you could machine the caliper mounting area to make up the minor difference if you had the tools but I don't think cutting any material away on a brake part bearing surface is a good idea. I just priced out all the new front end parts needed for the C2500 LD disc swap (not including the C20 lower A-arms I still need to get) and the tie rods & ball joints can be done for under $145 locally. I'm sure rock auto can do it for much less. Another $100 gets you rebuilt calipers, new brake hoses, pads & wheel bearings. All totaled I will have right at $400 into the swap with an all new front end to go with it.
02-22-2010, 02:10 PM | #20 |
Seems like I saw some info a while back where they offered a kit that included caliper brackets that will bolt onto drum brake spindles and also the calipers, rotors, hoses, bearings, seals etc.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-22-2010, 02:18 PM | #21 | |
Some rare JL-8 optioned first gen Camaro's and all C3 Vette's did the same thing. Floating rotor over drum brake hubs with longer wheel studs and brackets to bolt up the Vette calipers. I considered making my own kit using 6-lug 4x4 front rotors over the stock drum brake hubs and building caliper mount brackets to bolt up a set of calipers but chose to keep the nice calipers I have for use on my Camaro and go the C2500 disc swap route instead for the C-10.
