Old 02-10-2010, 10:59 PM   #1
Strut
Strut's Avatar
700R4......Advice.
I've got a 700R4 out of a 89-90 4.3 S10. Looking to put it in my 72....
I know that I need a crossmember.
Prolly going to need to shorten my drive shaft.
Maybe different linkage.
Also gonna rebuild the trans and install a shift kit. Get a new torque converter too....
I was lookin to you guys to see if there is anything else that I may need to make this change. Maybe someone has done this already or something like it.... Any help will be appreciated.
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 02-10-2010, 11:01 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 700R4......Advice.
You're going to have to give some information about what transmission your truck has now. There is no way to answer your questions accurately without knowing that.
Old 02-10-2010, 11:04 PM   #3
Strut
Strut's Avatar
350 motor, with 350 trans....sorry
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-10-2010, 11:12 PM   #4
Tx Firefighter
Since you're already running an auto trans you won't need a crossmember or shift linkage. Just reuse the original stuff with the 700.
Old 02-11-2010, 12:11 AM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
you will also need a the TV cable the overdrives use
Hubscrub is offline   Reply With Quote
Old 02-11-2010, 01:15 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I used the TVmadeEZ TV cable kit and Torque Converter Lock-up kit from bowtieoverdrives.com
It's been a few years and at least 10K miles, I'm happy with the set up.
I had to get an auto cross member, shorten my driveshaft and change out the yoke, BUT I had a 3spd manual in my truck. Not sure how it would go with an auto already in there?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-11-2010, 07:25 AM   #7
Tx Firefighter
If his current TH350 has a 9 inch tail housing it will be the same length as the 700R4 and use the driveshaft as is with no modifications. If it is a 6 inch tail housing TH350, he will need to shorten his driveshaft by 3 inches. Regardless of length, the yoke is the same between 700s and TH350s.
The current auto crossmember and mount will work. He will have to simply slide the crossmember back on the frame rails and drill the new holes where it winds up sitting when the 700 is bolted to it.
Old 02-11-2010, 08:10 AM   #8
rsavage
rsavage's Avatar
Assuming you have a quadrajet, pick up the correct TV cable bracket for the carb. ( they are made for other brand 4bbls too) TV cable adjustment is critical and you will toast the trans quickly if not adjusted correctly. Bowtie Overdrives has tons of info on their site - good reading before you do the swap.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-11-2010, 08:18 AM   #9
Tx Firefighter
To add to rsavage's post, you can get the TV cable, brackets, and carb linkage from an 82-86 truck at the junkyard.
Old 02-11-2010, 08:29 AM   #10
Strut
Strut's Avatar
Are there gonna be any Speedometer issues? The 72 is cable driven, not sure about the s10....maybe digital?
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-11-2010, 08:42 AM   #11
Tx Firefighter
Cable speedo 700 works without mods. If you get an electronic VSS speedo 700 trans you have to buy a pretty expensive converter to make your mechanical speedo work.
Old 02-11-2010, 09:07 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
you can put gears in it also. remove extension housing, replace drive reluctor with a gear, replace sensor in housing with a gear and drive bushing, and reinstall. tell the guys at the dealer what rear end gears you have and your tire size. they can look it up in the book and get you the correct gears along with the bushing (part that the driven gear fits into. don't forget to get the little clip that holds the drive gear to the tailshaft.
68C15 is offline   Reply With Quote
Old 02-11-2010, 11:37 AM   #13
michael bustamante
michael bustamante's Avatar
this iswhat I did and I havent tried it yet as its not installed but it wasent a hard job, the only hard part was trying to find a gear puller long enought to reach the factory relucter gear on the driveshaft to remove it. once you take off the t shaft housing, youll see what I mean. Also, is a 700 r4 from a v6 the same as a v8? I thought there was something different about them that you couldnt hook them up to a v8
1967custom
michael bustamante is offline   Reply With Quote
Old 02-11-2010, 12:26 PM   #14
bsm78
not trying to hijack thread here but im wanting to do the same thing except my 72 orig came with a 3 on tree. now it has a shifter in the floor with a muncie four speed. or so im told. reverse is to the driver and back to the seat. just wondering what all i would have to replace.
bsm78 is offline   Reply With Quote
Old 02-11-2010, 05:11 PM   #15
Tx Firefighter
I haven't done this myself, but I can visualize what ya'll are talking about. If you don't have a puller with long enough jaws could you use a punch and hammer to tap it off ? Or a die grinder to cut a groove (carefully) into the wheel to release the tension and let it slip off ?
Old 02-11-2010, 05:33 PM   #16
michael bustamante
yeah tx, I cut a grove in mine in 2 places and a tap of the body hammer and it came right off but you have to be careful!!!! I almost touched the shaft with the mini dye grinder. the replacements Ive seen are plastic so you have to be careful putting those on as well, light even taps
1967custom
Old 02-11-2010, 11:04 PM   #17
dmec
dmec's Avatar
personally i would not use a 700 from an s10. they dont have the same clutch count as a v8 tranny. use 87 up v8. stronger trans.
dmec is offline   Reply With Quote
Old 02-11-2010, 11:22 PM   #18
68C15
blood type; Retumbo
68C15's Avatar
when I remove the reluctor I start by placing magnets I got from old fuel pumps tp catch the filings. then I use a hack saw to cut a diagonal slit across the face. then it simply sides off.
Old 02-14-2010, 12:55 PM   #19
Strut
Strut's Avatar
The Casting # just above the pan on the passenger side is:
9 THM 0236
Tail Shaft has this # on the side:
8642547-2
It is the long Tail shaft, approx. 7 1/4" long
The drivers side of the case on the Trans has this #:
8663548
Trans has the "K" on the Bell Housing.
Spline count is 27 on the out put shaft.
I would like to see how all this compares to a 700R4 out of a V8 application.
Thanks.
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-14-2010, 01:11 PM   #20
JimmyFloyd
I am interested in which trans would be the best one to get to swap in. I have a 4 speed, but would like to have an auto with overdrive as I plan to drive it onroad more than off.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 02-14-2010, 02:19 PM   #21
dmec
dmec's Avatar
the difference between a 700r4 from a 6 or 8 cyl is internal. v8 are stronger than the 6.
Old 02-14-2010, 07:17 PM   #22
Strut
Strut's Avatar
Are we talking the "Gears" being stronger or the "Clutchs"??
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-14-2010, 08:40 PM   #23
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
subscribed
Hottrucks is offline   Reply With Quote
Old 02-14-2010, 10:31 PM   #24
aintmisbehavinn
I'm wondering what the ideal swap would be, from which? Input?
aintmisbehavinn is offline   Reply With Quote
