02-11-2010, 11:38 AM | #1 |
PITbut
Did my first exhaust. Have a questioin or two.
Never done an exhaust before. Bent it and all that good stuff. Being my truck is a stepside with the gastank in the back and a wood floor, airbags and notched, i dont really have options on where to mount the mufflers.. Its 2.5 all the way back.
Someone said that being my mufflers are facing longways down that it may collect moisture.. Being i wont drive much, never in the rain, im not to worried about it. Also someone said i should maybe get smaller mufflers. Being i just spent 160 bucks on these two mufflers im not to happy right now. LOL. Anyone have any recommendations on some small, decent sounding round mufflers?? Heres the pic. Sorry, it was late and i was laying on my back with my phone.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-11-2010, 02:49 PM | #2 |
Re: Did my first exhaust. Have a questioin or two.
just drill a TINY hole on the lowest spot on the muffler for moisture to escape. As for smaller mufflers i dont know the smaller you get the louder you get.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
02-11-2010, 02:54 PM | #3 |
Never Ending Projects
The moisture is not from the rain but as the engine is warming up. It creates water vapor until everything gets up to temp. Short drives actually make it worst since everything doesn't get hot enough.
Do like said above, drill an 1/8" hole into the lowest rear point of the muffler. That will allow it to drain out. My Cherokee drips water from the stock muffler if I only have it running for a few minutes and not let it warm all the way up. Most stock vehicles do this.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-11-2010, 03:47 PM | #4 | |
PITbut
02-11-2010, 06:40 PM | #5 |
Go with cherry bombs if you still want different mufflers.
Cheapest best option there is. |
02-11-2010, 06:45 PM | #6 | |
PITbut
I heard they sound horrible. Mine will work, its just for some reason EVERYONE things they look ****ty there.. Its no lowere then any part of the exhaust. Bah, screw em. Not like you can see it anyways
02-11-2010, 06:54 PM | #7 |
In my opinion, your mufflers look just fine right there. I think you did an excellent install. Leave em'. If someone makes fun of it, just tell them that it looks better than one of those ricers with the muffler that's twice the size of the car. No doubt it sounds better too.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
02-11-2010, 10:19 PM | #8 |
Well, just to throw a out-of-the-box idea into the ring, I have a buddy who ran a 454 in a '65 and used 3" straight out the back with some steel wool poked into the ends of the pipes. He attached three stainless screws through the pipe to keep the steel wool from blowing out. May sound crazy, but it sounded really good. You can "tune" the sound by how much steel wool you put in.
02-11-2010, 10:45 PM | #9 |
It's your truck- go with what you like.
02-12-2010, 12:08 AM | #10 |
Nice lookin system When I worked in the muff shop, we did poke an 1/8" hole in the bottom of the muff(if the factory didnt allready put it there!) If the muff if pointed UP to the rear, punch that hole in the front(lowest point) to drain it. crazyAL
http://community.webshots.com/user/hotrodhorn |
02-12-2010, 12:41 AM | #11 |
I agree with A.K.A Josh ,your setup looks great.
02-12-2010, 01:37 AM | #12 |
PITbut
I went back to the shop tonight and took the exhaust out, finish welded it and installed the hangers.. I honestly COUL DNOT BE HAPPIER. They actually are higher in the rear then the rest of the exhaust.. SOUNDS AWESOME..
Now, if i can just figure why my fuel guage reads WAY PAST full and why my temperature guage goes WAAAYY past hot when its not then i would be good.. OH, and if i could adjust my damn lokar shift linkage correctly. ahaha
02-12-2010, 09:17 AM | #13 | |
02-12-2010, 10:56 AM | #14 | |
PITbut
As for the fuel guage, i will figure it out i think.
02-12-2010, 11:30 AM | #15 |
(Quote) "As for the fuel guage, i will figure it out i think."
Make sure all the wire connections at the fuel tank are good. I had the same problem once and thats what was causing it. If I remember right, there is a ground wire and it was not making a good ground? It was a while ago, don't remember everything.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van Last edited by chas350; 02-12-2010 at 11:34 AM. |
02-12-2010, 11:31 AM | #16 |
PITbut
Make sure all the wire connections at the fuel tank are good.[/QUOTE] Uhhhhmm, you mean make sure i have it plugged in... Uh, ya... I didnt. ahah.. Maybe NOW IT WILL WORK. ahah..
02-12-2010, 11:35 AM | #17 |
PITbut
Here it is, all tacked together. Right before welding. It came out REALLY well. The mufflers sit back up. I will get better pics once i get it home.
02-12-2010, 11:39 AM | #18 |
Looks good- you want to make a trip east and do mine?
02-12-2010, 11:40 AM | #19 |
PITbut
I wonder if they would let me check the bender as carry on. ahah.
