01-30-2003, 09:48 PM | #1 |
lowering ????
Is 2/4 level or is it 2/3 level I aready have front spring was going to put 2inch lowering blocks but thinking of trying to macke my truck level thanks moose
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr 7I JIMMY 350 4speed daily driver/next prodject 99Yukon wifes |
01-30-2003, 10:07 PM | #2 |
Fabricate till you "puke"
A 2" front/ 4" rear should get you pretty close to level. .....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-31-2003, 08:30 AM | #3 |
Old Skool Club
if the tires are the same size
I did a 2.5/4 drop, but used 235-60's on the front and 255-70's on the rear....so, it's got a rake to it. I like it, tho. Kinda hot-rod lookin'....like, big and little's.
I believe you'll have to use the same size tires all around to see it looking level. Otherwise, it won't be.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-31-2003, 09:54 AM | #4 |
I agree with ChevLoRay on that "nose down stance".......I like them with a little rake also.......crazyL
01-31-2003, 10:03 AM | #5 |
Working on a Nova.
I personally like a small rake myself!
Moose when it comes to lowering the front of your truck I know the springs are cheeper but I think it is best to start with the spindles then get a spring to drop you down an extra inch or two after you are done with all other suspension mods. since springs are one of the easier things to change! Also the spindles will not adversly affect your trucks ride characteristics! |
