V-8 conversion
I took out my inline 6 and gonna replace it with a 350. Do the motor mounts fit the same for the swap? And also it had a saginaw 4 spd in it and im puttin a turbo 350 back in it, what years of cross member do i need to replace it? If you guys have anything else i should watch out for let me know please
Josh ![]() 1968 C-10 Shortbox |
![]() Join Date: Sep 2007
Re: V-8 conversion
the motor mounts more than likely wont work unless you rig em to make them work, Im sure youll find v8 mount towers in the for sale section though
1967custom Last edited by michael bustamante; 02-11-2010 at 01:01 PM. |
Re: V-8 conversion
I have a 77 chev i took the 350 out of you think those will work?
Re: V-8 conversion
if you mod em I think they will but I dont know for sure. I know you can modify the big block ones to work in our trucks though.
1967custom |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: V-8 conversion
You can bolt the engine down to the engine stands you have right now. No mods or rigging needed. The factory had different frame mounts for factory V8 trucks which are several inches forward of the I6 frame stands. You can see the empty bolt holes in your frame in front of the existing mounts. There is no real disadvantage to using the I6 mounts other than the HEI distributor will be closer to the firewall. It doesn't hit, just closer.
If it bothers you having the engine back a few inches and the distributor close to the firewall get you a pair of factory V8 stands. If it doesn't bother you, rock on with your existing ones.
Re: V-8 conversion
am i still able to remove the distributor if need be?
Keep On Keepin' On
Re: V-8 conversion
I was sent the wrong motor perches (I6)...Didnt know...About pulled my hair out trying to get my 350 to sit right...If you can with I6 perches go for it, but I couldnt figure it out...Save your hair, find V8 motor perches...
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
Re: V-8 conversion
Absolutely
I don't understand the difficulty. The perches bolt to the truck with three bolts. Then the engine drops right onto the perches. No holes to drill, no prying, nothing. I have done it many times, most recently a month ago. What trouble did you have ?
Moderator
![]() Join Date: May 2007
Re: V-8 conversion
I have a set of factory small block V-8 motor towers, perfect condition. If you decide that you want to go that route I will sell them for $30 shipped to your door. I am going with a big block and don't need these anymore.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Aug 2001
Re: V-8 conversion
sounds like time to transplant that disc brake front cross member assy. (out of the 77) under that 68 if it's in decent shape. Then you can use those motor mounts. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Keep On Keepin' On
Re: V-8 conversion
the perches are different...are they not?? from I6 to V8?
Re: V-8 conversion
Yes they are, the SB will set back 3 1/2 " (plus or minus 1/8") , on the 6- 250 stands. It does fit tight to the firewall, but the HEI dist will fit, & YES you can remove /install it with the eng in place (Tx Firefighter allready mentioned this). He wasnt bull****tin you, I have done it 4 times myself
http://community.webshots.com/user/hotrodhorn |
#13 |
Cruzin
Re: V-8 conversion
the others are right, my 350 is mounted in place of the 6 cyl. i didn't have any problems at all
![]() [ATTACH] ![]() ![]() |
#14 |
Re: V-8 conversion
what mod to the wiring harness did you have to do in order to swap to the V8 and did you change the Radiator too?
#15 |
Re: V-8 conversion
Nice lookin pc! ....you really should hang a shroud behind that radiator , before the temps get too hot tho.... crazyAL
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 02-11-2010 at 11:25 PM. Reason: spelling..LOL |
#16 | |
Cruzin
Re: V-8 conversion
#17 | |
Cruzin
Re: V-8 conversion
![]() Quote:
![]() ![]() Last edited by Hubscrub; 02-12-2010 at 06:53 PM. |
